#36039 - 03/12/13 08:25 AM Invoices - Unable to Load Selected Spec
Carol Lord Openhym Offline
5 Corgis and Counting
Loc: Baltimore, Maryland USA
Invoices 9.0B (111102)
OS Windows 2008 R2
Terminal server environment
Data integrity = clean
My client just moved to a new terminal server.
(She was previously on another TS environment).
All seems to be working ok except when she goes to print an invoice, it says:
Unable to load selected specification 's:\newdata\mms\qi$men~1.mms for document '44477'.
But - curiously enough, the invoice prints just fine. The error pops up after the print status is at 100%.
I logged in and was able to open the spec file.
This also only happens when clicks the Print Button -- if she previews and prints from the preview window, she does not get the error message.
Thoughts?
Many thanks,
Carol Openhym
Edited by Carol Lord Openhym (03/12/13 08:27 AM)
Carol Lord Openhym
Allegro Automation, Inc.
Baltimore, MD USA
#36042 - 03/12/13 08:51 AM Re: Invoices - Unable to Load Selected Spec [Re: Carol Lord Openhym]
Carol:
1. When you moved to the new server did you just copy the programs or re-install them. If you copied then I susgest you re-install.
2. Have the user rights re-applied to all Adagio program and data, files and folders.
#36046 - 03/12/13 09:34 AM Re: Invoices - Unable to Load Selected Spec [Re: Carol Lord Openhym]
Hi Carol:
I noticed that the error refers to the file by its shortname (qi$men~1.mms). Adagio stores the shortname internally, not the long name. It may be that the file has now acquired a different shortname on the new server (ie. qi$men~2.mms). I don't know how the operating system decides how to number the shortnames. You can see if this is a problem by doing the following:
*Go to DOS prompt
*Change to the data folder
*DIR /X/P
* Look for the shortname attached to your invoice file
The /X parameter will display the shortname for any files that exceed the 8,3 format.
0 registered (), 352 Guests and 104 Spiders online.
14636 Topics
