#35836 - 03/04/13 06:23 AM GV Filter
Miriam Offline
Loc: Altona, MB
I am using this filter in a GV report:
and({Trx Type} = 1,{Job}<>100,or(and({Trx Date} >= {Start Date},{Trx Date} <= {As of Date}),and({Trx Date} >= {LY Start Date},{Trx Date} <= {LY As of Date})))
The filter evaluates okay but the problem is the {Job}<>100. It doesn't do anything to the View even though it's supposed to omit Job # 100.
Miriam Wiebil
#35837 - 03/04/13 06:29 AM Re: GV Filter [Re: Miriam]
Instead of {Job}<>100 use trim({Job})<>"100"
The Job number is actually a text field and needs to have quotes around it.
#35841 - 03/04/13 07:00 AM Re: GV Filter [Re: Steve Schwartz]
Miriam Offline
Loc: Altona, MB
This worked. Thanks.
My second question is: I am using this formula to calculate the variance between two columns (column E - column F).
=IF(OR(E10=0,F10=0),100,E10/F10)
I want my variance to show as a percentage and if I use this formula it works fine if column F is zero because then it shows 100, but if column E is zero I get an error even though it's supposed to show -100.
Miriam Wiebil
#35842 - 03/04/13 08:07 AM Re: GV Filter [Re: Miriam]
Hi Miriam,
Is this in the Financial Reporter or GridView?
In either case, you must test to see whether F10 = 0, since division by zero is undefined.
#35843 - 03/04/13 08:29 AM Re: GV Filter [Re: Retired_Guy]
Miriam Offline
Loc: Altona, MB
This is a GV report linked to Excel. With an XDView link it automatically updates Excel with the formula stored in Excel.
When I divide column E by column F I want the variance to show as a percentage. In the case where column F is 0 the formula works, but if E is 0 then I have an error and if both columns are 0 then it shows 100% where as it should show 0.
Miriam Wiebil
#35844 - 03/04/13 08:32 AM Re: GV Filter [Re: Miriam]
Are you getting the error in GridView or Excel? What EXACT error are you getting?
Please let us know what results you want for each of the following cases:
Code:
E10 = 0 and F10 = 0
E10 = 0 and F10 = 2
E10 = 1 and F10 = 0
E10 = 1 and F10 = 2
Edited by Andrew Bates (03/04/13 08:59 AM)
#35847 - 03/04/13 09:30 AM Re: GV Filter [Re: Retired_Guy]
Miriam Offline
Loc: Altona, MB
E10=0 and F10=0 show: 0%
E10=0 and F10=2 show: -100%
E10=1 and F10=0 show: 100%
E10=1 and F10=2 show: -50%
I was getting the #DIV/0 error.
Miriam Wiebil
#35848 - 03/04/13 09:52 AM Re: GV Filter [Re: Miriam]
Why -50%?
#35849 - 03/04/13 10:04 AM Re: GV Filter [Re: Retired_Guy]
Miriam Offline
Loc: Altona, MB
Because it decreased by 50%. For example if I have 50 in column E and 100 in column F then it means that the 100 decreased to 50 which is a variance of -50% (so whenever column F has a higher value than column E the variance will be negative).
Miriam Wiebil
#35853 - 03/04/13 10:53 AM Re: GV Filter [Re: Miriam]
Use:
Code:
IF(F10=0,
   IF(E10=0,0,1),
   (E10-F10)/F10
This will give you the percentage increase (decrease) between the two numbers.
0 registered (), 451 Guests and 3 Spiders online.
14627 Topics
