#3572 - 08/15/03 03:11 AM Re: Blank warning when starting Financial Reporter
Hello Susan Hayes,
My guess is that you'll find that the file "GLGROUP.DAT" is missing from the dataset. This file contains the default account ranges, and is maintained in Edit |Account Groups.
Interestingly, neither the Adagio, or ACCPAC Plus data Integrity Check functions notice this. ACCPAC Plus does notice if you try and start the General Ledger. Adagio does not. I can e-mail you an empty GLGROUP.dat if you need it.
#3573 - 08/16/03 12:50 PM Re: Blank warning when starting Financial Reporter
Lars Offline
Loc: Vernon, B. C.
Hi Susan - the cause of this error could be that the path used to the dataset is a UNC or that the folder names have spaces. In other words, check to see that you use a drive letter instead of path that begins with ''\\' and that the folder name is Program_Files instead of Program Files.
Hope this helps.
