#35652 - 02/19/13 02:38 PM Barcodes for things like ...
JohnK Offline
Good day to you all,
We are on a big push to implement Docushare. We are using barcoded routing codes in the Adagio reports that use forms that we can edit - everything is working great!
The incredible thing about Docushare is the full text search of the entire document - everything can be searched... So, for us, we can find propeller work on a specific vessel w/o knowing anything else...
There are some areas though that are not as easy for us to figure out (ie: are the folowing reports editable?)...:
1- AI - Invoice Posting Journal
2- AP - Manual Check Posting Journal,
3- AP - check Register,
4- AP - Invoice Posting Journal,
5- AP - Adjustment Posting Journal,
6- AR - Cash Posting Journal.
This might not be the entire list.
Are these report editable somewhere in the system and if so, do they use a naming convention or are these and others like them hard coded?
As always, thank you and,
Cheers, JK
#35656 - 02/19/13 05:26 PM Re: Barcodes for things like ... [Re: JohnK]
John:
Docushare performs a simple task offered by many solutions, that being to search for character strings within a PDF file.
You need to get the Adagio reports (mentioned in your post) into searchable PDF files. This can be done automatically with Adagio ePrint.
I'll send you a quote.
#35659 - 02/20/13 07:19 AM Re: Barcodes for things like ... [Re: Douglas Dickie]
JohnK Offline
Hi Doug,
Thank you for the offer of the quote for Adagio ePrint but we are building an enterprise wide document resource ergo, ePrint does not fit in.
I have no problem creating searchable PDF files from Adagio at this time even without Adagio ePrint.
To be clear, what I am trying to do is alter all the reports in Adagio to incorporate a bar code which can then be used for routing to the appropriate OCR zone sets.
This has already been done for those items that I can alter.
My question is are the reports noted above editable and if so, where are the templates?
Cheers, JK
#35671 - 02/20/13 02:24 PM Re: Barcodes for things like ... [Re: JohnK]
John:
If you would like our assistance to implement a solution, please contact us at service@accsyssolutions.com
#35686 - 02/20/13 06:58 PM Re: Barcodes for things like ... [Re: Douglas Dickie]
JohnK Offline
Hi Doug,
I have just fired off an email to you guys.
Thank you for posting up and,
Cheers, JK
2 registered (rah, Bruce Gardner), 247 Guests and 0 Spiders online.
14636 Topics
