#35290 - 01/30/13 03:08 PM Invoices - The style code B, is not defined in the
JohnK Offline
Good day y'all,
We have an open batch and tried to print an already created invoice.
It appears that the style codes were not added before the invoice was created.
A bunch of errors generate but the report still appears.
What should we do (apart from adding the style codes)?
Thank you and,
Cheers, JK
#35291 - 01/30/13 03:31 PM Re: Invoices - The style code B, is not defined in the [Re: JohnK]
Hi John,
Style codes are assigned to items and are used when printing forms. The form must contain a Detail section assigned to each style code you use for your items, including Inventory items if that is integrated.
The error means that you have an item with a particular style code, and a detail section pertaining to that style code does not exist. The result is that those items will be skipped when printing.
The solution depends on the problem. Does the item(s) contain an unexpected style code value that was not meant to be defined on a specification? If so, then you will first need to ensure that your items have the correct style codes assigned. Then you will have to delete and re-insert the incorrect items, as changes made to the item masters will not affect items already on invoices. If you have a large volume, you may be able to archive the batch(es), run the Update Archive Batches process for items (de-select the amount fields), and then restore it back to an open batch.
If the problem is that the style codes are defined correctly and assigned to the appropriate items, the solution is to edit your specification and create a new detail section for each missing style code. It may be as simple as copying an existing section and all objects within, and pasting to create a new section from that.
If either or both solution appears daunting, then you should contact your Adagio consultant for assistance.
#35296 - 01/31/13 06:37 AM Re: Invoices - The style code B, is not defined in the [Re: Softrak Support]
JohnK Offline
Thank you - this is very helpful and what we need to correct the problem.
As you state, beyond this we will contact our Adagio consultant.
Cheers, JK
#42865 - 08/29/14 06:10 AM Re: Invoices - The style code B, is not defined in the [Re: JohnK]
CATHBAR Offline
Stranger
Loc: CANADA
HELP! How do you set up or define style codes?
#42867 - 08/29/14 06:23 AM Re: Invoices - The style code B, is not defined in the [Re: CATHBAR]
Edit the specification you are using to print the document, and insert a section. Set the section properties to the Style Code you want.
There is a recorded webinar available that describes how to use Invoices forms designer.
0 registered (), 237 Guests and 2 Spiders online.
14617 Topics
