#35183 - 01/23/13 12:14 PM Crystal Report year-to-year analysis report help
Ryan Offline
Loc: Manitoba, Canada
I am trying to set up a report to compare the year to year revenue generated by our customers for each period and ytd. So far I've set up the main report with the customer field. I then created two sub-reports, one for the current year and one for the previous year and linked them to the main report by customer name. I've grouped the sub-reports by customer name and set it up so only the total for each customer shows up on the main report. Using was the only way I could figure out how to do this.
I'm having trouble with two areas. First, if the the customer has no revenue for that accounts in both years, I want to eliminate them from the report. Second, I can't figure out how to get the total for each year on the last page.
Any help/ideas are appreciated.
Ryan
#35188 - 01/23/13 01:46 PM Re: Crystal Report year-to-year analysis report help [Re: Ryan]
Hello Ryan:
Let me suggest a different approach. Base the report on the transaction table with a link to the Customer table. Sort and group by Customer code. Filter the report to transactions in the past 2 years . Create a separate formula calculation for each period you want to see on the report (using IF). This approach solves both of your dilemmas and will likely run faster too.
#35201 - 01/24/13 12:52 PM Re: Crystal Report year-to-year analysis report help [Re: Bruce Gardner]
Ryan Offline
Hi Bruce,
I've redid the report and I'm really close. I need some help with the IF statements in the formulas. I've set up a Parameter field called Date that enables the user to enter two ranges of dates for comparison (ex. 01/01/2012-31/01/2012 and 01/01/2011-31/01/2011). I also have a Parameter field to select the revenue account. I have two formulas set up, one for each date range so if the account is 0 it won't print the company name. I am am having trouble separating the Date ranges so that one formula does the current year figures and one formula does the previous years figures.
Any suggestions?
Ryan
#35209 - 01/24/13 08:02 PM Re: Crystal Report year-to-year analysis report help [Re: Ryan]
Ryan:
Do you have 2 date parameters? Are the date parameters defined as ranges? Are you calculating 2 totals for each Customer: Current Year and Last Year?
Assuming you have used range parameters, the formula to calculate This Year would be something like:
If [Transaction date] in [This Year Range Parameter] then [Transaction amount] else 0
The actual fieldnames would vary depending on which tables you are using.
#35210 - 01/25/13 04:55 AM Re: Crystal Report year-to-year analysis report help [Re: Bruce Gardner]
Ryan Offline
Thanks Bruce I'll give it a try.
