#33795 - 11/07/12 11:13 AM Control Panel Display settings affecting print out
Osis Offline
Adagio Groupie
Loc: Lac du Bonnet, Mb.
I have my control panel display settings set to 125%, and after reading forums now realize that is a problem.
However when I change this to 100% my printer output enlarges so that it is not satisfactory.
My question is how do I get my print specs to work properly with the Control Panel display set at 100%?
#33797 - 11/07/12 03:56 PM Re: Control Panel Display settings affecting print out [Re: Osis]
Have you tried opening the specification and saving it again?
#33806 - 11/08/12 02:34 PM Re: Control Panel Display settings affecting print out [Re: Retired_Guy]
Osis Offline
Adagio Groupie
I have opened a OE$ spec, renamed(saved as), and then tried print preview, with no different results.
I am now starting to question whether the spec was written(at time of install) with the control panel display setting set to 125%. Would this make a difference?
#33809 - 11/08/12 03:25 PM Re: Control Panel Display settings affecting print out [Re: Osis]
Ralph Allan Offline
Osis: You are likely correct: The spec was created on a system with large fonts enabled and "juggled" to make it work.
This all relates to the WYSIWIG (What You See Is What You Get) nature of Windows printing.
Ralph Allan
Business Computer Centre
Prince George BC Canada
#33824 - 11/09/12 10:03 AM Re: Control Panel Display settings affecting print out [Re: Ralph Allan]
Osis Offline
Adagio Groupie
Is there an "easy" Fix for this?
#33827 - 11/09/12 11:45 AM Re: Control Panel Display settings affecting print out [Re: Osis]
Probably not.
0 registered (), 91 Guests and 2 Spiders online.
14673 Topics
