#33692 - 10/24/12 10:08 AM Tax not calculating for items on invoice
Ryan Offline
Loc: Manitoba, Canada
i'm setting up a new company in Adagio and am entering the historical invoices into Adagio Invoices. I've set up the items, tax codes, etc. My problem is when i enter an item into an invoice that has a Item Total of less than $100 it doesn't calculate and add on the 5% GST. If the Item Total is over $100 it calculates it. i can't figure out why.
RD
#33696 - 10/24/12 12:02 PM Re: Tax not calculating for items on invoice [Re: Ryan]
Hi Ryan,
Tax group jurisdictions (GST, PST, etc) can optionally be defined with a minimum tax, so that if the total calculated amount of tax is less than the minimum, then 0.00 tax is actually used for the item. I suspect that this is what's happening, with a minimum tax of 5.00 (or 5% of 100.00). To check this, edit your Tax table and look at the GST jurisdiction tab. If you see a minimum tax not equal to zero, then it can be changed to zero so that GST gets calculated regardless of how little the amount.
Tax table changes cannot be saved when the tax reports have information or there are open batches. If you need to make a change to a tax table and the program won't let you save the change, you have to archive all open batches amd print/purge the tax reports. You may want assistance from your Adagio consultant before doing these things.
0 registered (), 298 Guests and 0 Spiders online.
14636 Topics
