Hi, Mike,
What happens if you use a different quote spec? If you don't have one, you can get one of the sample data specs by accessing the Spec Designer and selecting File | Open Template | selecting a sample data Quote spec and saving it to your data folder using your data extension.
If you receive the same warning again, can you try using the same sample data Quote spec within Softrak\ACWIN\Samdata? Do you still receive the warning?
Even if you were to set the Workstation Options for the spec printer to Specific, you could still access AdagioPDF by selecting Setup on the spec print window and selecting the AdagioPDF print. More work, agreed, but might be another thing to try.
Let me know,
