#33390 - 09/26/12 12:40 PM Invoice # went from 1238 to 1240 no 1239
SChis Offline
Casual
My Invoice numbers skipped a number..went from 1238 to 1240 no 1239! After I invoiced 1238 I did a credit note...did this cause me to jump a number? Did Integrity check...all okay. Can I create a manual invoice 1239? HELP! I hate being out of sequence.
#33391 - 09/26/12 12:49 PM Re: Invoice # went from 1238 to 1240 no 1239 [Re: SChis]
Hi SChis,
Yes, if you created a new invoice document, then this 'uses' an invoice number, even if you later on change the document type to be a credit note. It has to be this way, because the document number is determined on creation, not when saving or posting.
The way to prevent this scenario is to select Credit Note as the document type on the 'new invoice' screen when selecting the customer. Once you are in the invoice and editing it, it is too late for the number.
If you want to see a list of 'missing' document numbers and reasons, there is a report called the 'Deleted invoice audit list' on the Reports menu, which tracks invoice numbers that were 'used' but not posted.
And to answer your question, yes you can override the invoice number on the Totals tab to use 1239. But then the invoice number that was previously generated will now be a 'missing invoice' for the same reason. You can reset the Next invoice number to use in the company profile.
Edited by Softrak Support (09/26/12 12:51 PM)
Edit Reason: more information
#33394 - 09/26/12 02:07 PM Re: Invoice # went from 1238 to 1240 no 1239 [Re: Softrak Support]
SChis Offline
Casual
Which is exactly what I did. Thank you so much. I will be more careful next time.
Edited by SChis (09/26/12 02:08 PM)
