#3288 - 04/15/03 01:47 PM Re: Printing Error
Hello Classic Moving,
When you reinstalled Quik Invoice for Windows did you install an older version?
The error message refers to a function that was introduced in later versions of Quik Invoice for Windows. Make sure that you have the most current version installed.
#3290 - 04/15/03 02:41 PM Re: Printing Error
Have you been printing multiple copies of documents? If you have been printing multiple copies, you must have been using a later version than 6.2B. The feature for multiple copies was not added until 65A.
If you have not been printing multiple copies, try printing a sample invoice from the sample data. If it prints properly, you may have a damaged specification file.
#3292 - 04/16/03 03:36 AM Re: Printing Error
Dear Classic Moving,
Since the printing of sample data worked correctly it is likely that your production specification file has become damaged.
Try restoring a backup of the spec file only (from when the invoice printing was okay). If you can’t find a backup where the spec is still in tact – recreate the invoice specification with Designer.
Best Wishes!
