#32584 - 07/13/12 02:25 PM Clearing the cheque rec
JeanB Offline
Loc: Kelowna, BC
Could you please tell me the benefit to clearing the cheque reconciliation in A/P? We've been using the module since 2007 and I have never cleared the cheque rec, I like to be able to see all the cheques at a glance. But last year we issued cheque 9999 and made the mistake of starting our cheque numbers back at 1 instead of carrying on to 10000. I'm at the point with our cheques where we are starting to duplicate numbers. I can still post the duplicate cheque number but it's a pain to enter multiple cheques with duplicate numbers because it tells me each time that the cheque number has already been posted. Are there any other benefits to clearing the cheque rec? do most of your Adagio clients clear it? If I were to start clearing it each month what would be a reasonable way to implement this?
Jean
#32586 - 07/14/12 02:08 AM Re: Clearing the cheque rec [Re: JeanB]
Hi Jean
The purpose of the check rec file is to support the bank reconciliation. It is not designed to be used as a way to quickly look up an issued check, although it can serve that purpose. There are other ways, for example the Check Number Audit List.
There is no reason to keep any checks in the check rec file other than outstanding checks and recently issued ones. Cleared checks and other non-outstanding checks just clutter up the file and make it harder to use the file for its intended purpose.
Specifically, what I like to do each month after clearing the checks off the bank statement is to print a list of the checks I just cleared and make sure the total agrees with the bank statement's list of cleared checks. You can't do that if you have prior months' cleared checks still sitting there.
If you decide to purge the old non-outstanding checks, the way to do it is to "print" the check reconciliation report, selecting all statuses, and then say yes when asked to clear non-outstanding checks. I put print in quotes because I wouldn't suggest printing to paper; I would suggest printing to PDF because the report may be very long.
#32686 - 07/20/12 11:56 AM Re: Clearing the cheque rec [Re: Steve Schwartz]
JeanB Offline
Loc: Kelowna, BC
Thank you Steve - you've totally cleared this up for me.
0 registered (), 255 Guests and 7 Spiders online.
14569 Topics
Max Online: 1211 @ Today at 01:32 PM
