Hi Andrew
Price Lists codes are already in use.
Let me suggest two changes to OrderEntry that would go a long way towards resolving the two issues above.
#1) Allow for negative quantities on orders, which can be turned into credit notes/negative invoices. It would be fine if the negative quantities reflect in the "On SO" field, since that would accurately describe the status of the soon-to-be-returned item.
#2) Pull the inventory optional fields into an order, so that they can be edited just like customer optional fields.  I'm sure you've heard complaints about how few editable text fields there are when entering item details on an order, so this is very needed.
For now, I'll advise Kristin to continue tracking pending returns manually, and to enter a reason code as a prefix in the item description field.
