#32316 - 06/19/12 05:12 AM error 1342
TCoon Offline
New Guy
Loc: Canandaigua, NY USA
(66.202.29.169)
When running day end in order entry module, we constantly get "error 1342 ocurred when attempting to write record to tax groups". This error has ocurred daily since installing adagio(July 2011) and is very time consuming as it pops up for each invoice. I have researched it under the help menu and on this forum but havent found any possible reason and or solution. Thanks for any advice you have to offer.
#32318 - 06/19/12 06:05 AM Re: error 1342 [Re: TCoon]
Version?
Does everything pass the Data Integrity check?
Otherwise there's a problem with the install.
Edited by Andrew Bates (06/19/12 06:06 AM)
#32322 - 06/19/12 07:14 AM Re: error 1342 [Re: Retired_Guy]
TCoon Offline
New Guy
(66.202.29.169)
Version- 8.1D
Yes, everything passes the data integrity check.
Thank you...
#32323 - 06/19/12 07:30 AM Re: error 1342 [Re: TCoon]
And the date after the version? See Help | About.
If you run Help | System Status does it complain about anything? Server Version?
#32324 - 06/19/12 08:22 AM Re: error 1342 [Re: Retired_Guy]
TCoon Offline
New Guy
(66.202.29.169)
The order entry module is Version 8.1D (110316)
I ran the system status and found we need to upgrade quite a few things...
The only error/problem it had was in payables, "not setup for checking report tables, missing [J:\softrak\system\qrasp\PO\QRTIR65A.qrw]"
#32325 - 06/19/12 10:08 AM Re: error 1342 [Re: TCoon]
Yes, that's not the current version of OrderEntry, or indeed even the current Service Pack level of OrderEntry V8.1D.
Download and install the Service Pack for OrderEntry V8.1D and see if that resolves the problem.
#32326 - 06/19/12 10:13 AM Re: error 1342 [Re: Retired_Guy]
TCoon Offline
New Guy
(66.202.29.169)
Thank you, i will do the upgrades and let you know...
0 registered (), 155 Guests and 1 Spider online.
1874 Members
14557 Topics
