#31765 - 04/30/12 01:58 PM GL Code change in POs
Acrylon Offline
Is it possible to change the GL coding of an item when doing a receipt in Adagio POs? It is for an inventory item where the GL is defaulting to what the category code is.
Cam
#31766 - 04/30/12 05:03 PM Re: GL Code change in POs [Re: Acrylon]
Cam:
I don't believe this is possible.l
#31767 - 04/30/12 05:10 PM Re: GL Code change in POs [Re: Douglas Dickie]
Hi Cam
It's possible, you have to change the category field to one which has the desired COGS account defined. I'm assuming that's the GL account you want to change.
#31769 - 05/01/12 09:03 AM Re: GL Code change in POs [Re: Steve Schwartz]
Acrylon Offline
Hi Steve,
I could change the category code, but it doesn't change the GL Account/Dept. The category code i'm changing it to does have a different GL.
Does this mean I need to fix it a different way?
#31770 - 05/01/12 09:45 AM Re: GL Code change in POs [Re: Acrylon]
Hi Cam
I would guess that if it isn't changing the GL account and it should be, it's a problem with the program.
#31771 - 05/01/12 10:17 AM Re: GL Code change in POs [Re: Steve Schwartz]
I'm confused.
Surely, when receiving inventory, you would want to be choosing a different control account (which is for the debits to inventory on a receipt), rather than the category which controls the COGs account to credit for the sale?
POA does not allow you to change the control account on an line receipt (and it's unclear to me why you'd even be interested in changing the Category of the line detail).
From the Help text:
Quote:
Category (required): The item category defaults from the IC Item or Sundry Item table category. Although you can change the category code, it will not affect any account posting because the item category determines the sales accounts for the item.
Edited by Andrew Bates (05/01/12 10:19 AM)
Edit Reason: Added Help reference
#31775 - 05/01/12 11:16 AM Re: GL Code change in POs [Re: Retired_Guy]
Acrylon Offline
We had someone create a bunch of POs with the wrong category code on items (they created the items as well).
I was hoping we wouldn't have to redo the line items, but i guess we will.
0 registered (), 181 Guests and 0 Spiders online.
1865 Members
14499 Topics
29 30
