#31622 - 04/16/12 10:55 AM Email Setup for Microsoft Exchange
Acrylon Offline
Our company recently changed email systems. We were operating on a POP3 email server, but have now moved onto our new Microsoft Exchange server. With this change, we also have new incoming and outgoing mail server addresses.
When we were operating on our POP3 email, we were using the Mapi email method within Agagio OE, with our employee's appropriate return address (i.e. Jane@abc.com). This would then allow our employee to open up the email queue of invoices, and send them via Outlook Express on our terminal server. (with the appropriate SMTP settings entered in Outlook Express)
Once the invoice email was sent successfully, A 'C' would appear in the Status column of the email queue, otherwise an 'H' would appear to signify an email error.
Now for the issue...
On our new Exchange server, I have tried reconfiguring the Mapi Outlook Express settings, as well as the Direct email method settings in OE, but have had no success with regards to sending invoice emails to external email addresses.
Using both configurations (Mapi and Direct), I am able to complete test emails and send invoice emails to internal email addresses (i.e. Jane@abc.com to John@abc.com). A 'C' will appear beside the invoice in the email queue, and the internal recipient will receive the email with the invoice attached. However, if I try to send invoice emails to external email addresses (i.e. Jane@abc.com to client@external.com) using the Direct email method, the invoice email will not go. A 'C' will not appear in the Status field of the invoice in the email queue, and neither will an 'H', signifying failure. The Status field will just remain blank as though I didn't even try to send the email.
If I try to use the Mapi method with the same SMTP email settings within Outlook Express on our terminal server, I receive the following error when sending to an external email address:
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'client@external.com'. Subject 'Adagio OrderEntry Test Email', Account: 'Outlook Express Terminal Server', Server: 'exchange.abc.local', Protocol: SMTP, Server Response: '550 5.7.1 Unable to relay', Port: 2525, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
Am I missing something here? Or is the only solution to first send each invoice to an internal Exchange email account, then forward it to the client via the employee's Outlook(2007 or 2010) or our Outlook OWA service?
The only reason I'm first questioning Adagio's capability to send to external email addresses via Exchange, is because we currently have hp photocopiers that use the same SMTP configuration, and are capable of sending to external email addresses outside of our Exchange server.
Any advice or suggestions would be appreciated... Thank you,
#31627 - 04/16/12 01:34 PM Re: Email Setup for Microsoft Exchange [Re: Acrylon]
I had an similar issue with exchange server using the Direct emailing. It was solved when the specific ip address was allowed outgoing email.
#31628 - 04/16/12 07:42 PM Re: Email Setup for Microsoft Exchange [Re: Patricia B.]
Bob Wisener Offline
Adagio Conductor
I'd recommend that you use the direct method and change the port from 25 to 587. I use the latter, when the server refuses to relay an email. Google, 'smtp port 587 relay' for details.
Bob Wisener
Dakota Software
#31631 - 04/17/12 06:54 AM Re: Email Setup for Microsoft Exchange [Re: Bob Wisener]
Acrylon Offline
Thanks for the suggestions thus far; however, applying them has been unsuccessful.
Our IP address is permitted to send outgoing email and is being used by multiple devices to do so already.
I tried port 587 for the direct method as well. I was still not capable of sending test emails and invoice emails to an external email address.
Any other suggestions???
#31633 - 04/17/12 07:36 AM Re: Email Setup for Microsoft Exchange [Re: Acrylon]
When you say that your IP address is permitted to send outgoing email, are you referring to the workstation ip address? I did not do it myself, but I was told that the workstation needs to be allowed.
#31643 - 04/17/12 11:14 AM Re: Email Setup for Microsoft Exchange [Re: Patricia B.]
Acrylon Offline
We have our Adagio operating within Citrix, if that helps further describe our situation...
Before switching from our POP3 email server to our Exchange email server, we were using Outlook Express/Outlook within Citrix, and were using the same port (2525). This is why I am fairly confident that Citrix is capable of sending/receiving email.
Thank you for the suggestions thus far.
Anyone have any other suggestions?
#31644 - 04/17/12 11:50 AM Re: Email Setup for Microsoft Exchange [Re: Acrylon]
Chris McDonell Offline
Adagio
Loc: Vancouver, BC, Canada
Try Bob's suggestion and switch to Port 587 from 2525.
I do not beleive that Adagio direct email does work with SSL at this time.
If you still are using Outlook (32bit) then Mapi should work.
What version of OrderEntry are you using?
Edited by Softrak Support (04/19/12 10:59 AM)
Edit Reason: typo
#31759 - 04/30/12 10:20 AM Re: Email Setup for Microsoft Exchange [Re: Chris McDonell]
Acrylon Offline
Just to provide an update. The solution involved configuring our exchange server to accept and allow emails sent from Adagio within Citrix.
We were able to send invoice emails using both the MAPI and Direct method through port 2525.
1 registered (Bruce Gardner), 587 Guests and 4 Spiders online.
14578 Topics
