#31538 - 04/04/12 09:33 AM Data Integrity Errors
jill Offline
Stranger
Loc: Hanover, On
Working in Payables, I entered my invoices, posted batch and went to print invoice posting journal. An error access violation warning appeared and I could not exit from this. I shut the computer down and restarted. I then did a data integrity check which found 128 errors. This is the first time I've experienced any errors. What do I need to do to remedy this?
#31540 - 04/04/12 10:32 AM Re: Data Integrity Errors [Re: jill]
Jill:
What version of Payables are you using? Is this the first time you've run the Data Integrity Check since you upgraded? There's a very good chance that those errors are unrelated to what you experienced. Could you use the mouse to select those errors, copy the highlighted block (using [Ctrl][C]) and paste it here? The Data Integrity Check has recently been upgraded to flag things that it used to ignore before. If that's the case, the messages can be resolved by using the "Rebuild" button.
#31542 - 04/04/12 10:52 AM Re: Data Integrity Errors [Re: Bruce Gardner]
jill Offline
Stranger
Loc: Hanover, On
Hi Bruce,
I haven't upgraded my payables lately. Could this have anything to do with our new fiscal April 1st?
A/P Vendor Notes Detail ... Checked OK
A/P Vendor Alerts ... Checked OK
A/P Terms ... Checked OK
A/P Tax Descriptions ... Checked OK
A/P System Check Paylist ... Checked OK
A/P Check Reconciliation Header ... Checked OK
A/P Check Reconciliation Detail ... Checked OK
A/P Check Reconciliation Pending ... Checked OK
A/P Transactions ... 26 error(s) found
A/P Transaction History ... Checked OK
A/P Transaction Matching ... Checked OK
A/P Retainage File ... Checked OK
A/P Revaluation Criteria ... Checked OK
A/P G/L Disbursements ... 102 error(s) found
A/P Profiles ... Checked OK
A/P Smart Finder Control ... Checked OK
A/P Import Defaults Field Values ... Checked OK
A/P Import Export File header ... Checked OK
A/P Import Export file Details ... Checked OK
A/P Filter Matches ... Checked OK
A/P Filter Master ... Checked OK
A/P Invoice Batch Header 105 ... Checked OK
A/P Invoice Batch Detail 105 ... Checked OK
A/P Invoice Batch Header 106 ... Checked OK
A/P Invoice Batch Detail 106 ... Checked OK
Application Integrity skipped due to errors in File Integrity
Finished at: 2012.04.04 10:46:36
#31543 - 04/04/12 11:15 AM Re: Data Integrity Errors [Re: jill]
Hi Jill:
That's not what I expected to see. I'll let Support weigh in on this one. And no, the fiscal year-end isn't a factor.
#31548 - 04/04/12 11:50 AM Re: Data Integrity Errors [Re: Bruce Gardner]
Hi Jill,
File integrity errors tend to be a mis-match between the data and the index. If posting gets interrupted, this is a likely result.
The most ideal solution is to restore your data from a good back-up, prior to posting the batch.
The next best solution is to make a backup of the data as it is now, run the integrity check again, and choose to Rebuild the errors. You might get another backup of the data with a 'Rebuild' suffix, to indicate that this data backup has integrity errors and was made as part of a Rebuild process. After rebuilding, run the integrity check again and the data may be clean, or there may be different errors found that also need to be Rebuilt. Finally, check the data to see if the correct information is there or if it is missing.
The third possible solution is to have the data repaired, if it is not correctly fixable by the Integrity Check and there is no good recent data back from wich to restore.
Whatever you do, you may need to be in contact with your Adagio consultant to advise on the best route for your situation.
#31554 - 04/04/12 01:40 PM Re: Data Integrity Errors [Re: jill]
accountability Offline
Loc: OWEN SOUND, ONTARIO
Jill... I'll call you tomorrow first thing to resolve. We may get to find out how good your backup is. As well... how has the server been operating lately? Any changes? Still in the dirty furnace room? Linda
Linda Droine
AccountAbility
Owen Sound, Ontario
accountability@bmts.com
0 registered (), 120 Guests and 5 Spiders online.
14579 Topics
January
