#3153 - 03/12/03 01:23 PM Re: disbursement code report
Hello J Randy,
Time&Billing has all the same reports that TBR DOS had.
Which report did you use when you were running TBR?
#3154 - 03/12/03 07:32 PM Re: disbursement code report
Hello jrandy,
I noticed in your post that you are using Quickbooks to enter your disbursements and then reconciling to those entered in Time&Billing. I just wanted to let you know that Adagio Payables provides an automatic interface with Adagio Time&Billing. You can allocate an invoice directly to a file/docket in Time&Billing at the time it's entered into Payables (invoices can be allocated across multiple client/files) and the disbursement batch is automatically created for you in Time&Billing. You can control markups automatically.
Sorry to interject...
#3157 - 03/13/03 01:07 PM Re: disbursement code report
Hello jrandy,
I have been able to duplicate your problem. Investigating your question, I have discovered an issue with converted Disbursement codes.
To correct the issue, you will need to Edit and OK each of your disbursement codes under Edit Disbursement codes.
#3158 - 03/14/03 03:28 AM Re: disbursement code report
Hello jrandy,
OK, I understand. I just wanted to make sure you were aware that there was a solution that would not require duplicating the data entry between entering your invoices in Quickbooks and then entering the re-billable disbursements in Time&Billing. I agree it might be overkill. I just hate seeing duplicate data entry, as it doesn't contribute much towards the "quality of life" in the accounting department .
Thanks for bringing the conversion issue to our attention.
