#310 - 12/01/99 02:21 PM Critical Error in QC+Win
Hi, I am getting the following error when I try ti enter QC Plus for Windows after entering user information:
Critical error [1302] unknown DOS error accessing EZTASKS file.
Any ideas?
#311 - 12/01/99 05:42 PM Re: Critical Error in QC+Win
Hi, Lucas
Please refer to Chapter 1 in the QCWIN manual, pages 1-19, 1-20. It will explain in more detail about currency & EZTASKS files.
Basically, QCWIN will attempt to automatically select the locations of the currency and EZTasks files for you. By default, QCWIN selects the HIGHEST network drive containing an \ASP directory. IF YOU HAVE ACCPAC PLUS or Softrak products INSTALLED ON MORE THAN ONE NETWORK DRIVE, YOU MUST MAKE SURE YOU CHOOSE THE CORRECT DRIVE.
The currency path MUST contain files called MCCODES.LD4 and MCDEF.LD4. If you are running ACCPAC Plus, those files are usually located in your \ASP directory. For example, if ACCPAC Plus is installed on your hard drive, you would generally find those files in C:\ASP.
If you are using ACCPAC Plus, QCWIN and ACCPAC Plus modules should have the same currency path.
If you attempt to select a path in which the above-mentioned files are NOT found, you will get an error message. Select the path again using the browse button.
(If the wrong paths are chosen, rename or remove the files EZCURFIL.LD4 and EZCOMFIL.LD4 from your data directory. Start the Adagio product and open the database. The EZFile Directories dialog will be displayed. Enter the correct path information, and proceed from there.)
Hope this helps!
