#30936 - 02/15/12 10:18 AM check reconciliation report missing pennies
Joan Offline
Casual
Loc: MD, USA
Can anyone tell me the status of the accounts payable fix dealing with missing pennies on the check reconcilaiation report?
My client's data file has been forwarded to Softrak and Softrak agreed that the problem deals with a bug in the software, any idea when this fix will be avabialbe?
We really need our pennies.
Joan
#30940 - 02/15/12 11:47 AM Re: check reconciliation report missing pennies [Re: Joan]
Hi Joan,
The total field just has to be made wider. Use your copy of Crystal Reports for Adagio to widen the total field and copy the modified report into the APWIN\ModRP Folder.
The pennies are not "missing", it's just that the total amount of their reconciliation is so large that Crystal is rounding the amount to make it fit in the report field.
#30947 - 02/15/12 01:52 PM Re: check reconciliation report missing pennies [Re: Retired_Guy]
Hi, Joan,
There was a problem reported in a particular client's data but the report was 'worked' to accommodate it. This was released in the AP8.1D upgrade.
What version is your client using now? If they're not on 8.1D, they should upgrade. If they are using 8.1D then I suspect that Andrew's solution is definitely the way to go.
#30950 - 02/15/12 04:48 PM Re: check reconciliation report missing pennies [Re: Softrak Support]
Joan Offline
Casual
Loc: MD, USA
Thank you
I will check on that now.
Joan
#30952 - 02/15/12 05:56 PM Re: check reconciliation report missing pennies [Re: Joan]
Carol Lord Openhym Offline
5 Corgis and Counting
Loc: Baltimore, Maryland USA
To Softrak Support & Andrew -
This is a client of mine. Of course, my first solution was to modify the report with Crystal. It did not work. It was a number of months ago so I cannot recall the details -- but I sent the data to Leigh and she confirmed and reported the issue to Softrak. She confirmed that it was a bug.
The solution - no, the work around, was to print Preview, sent to Excel and the cents appear.
Joan - we should plan to get together and do your updates anyway, either you or Tammy contact me and we can schedule. I know it's crazy busy season for you right now, but it should not be too time consuming to install the updates and see if it makes a difference in the bank rec.
Hopefully the 8.1D will fix it - because it is a real inconvenience, needless to say.
Carol
Carol Lord Openhym
Allegro Automation, Inc.
Baltimore, MD USA
#30978 - 02/17/12 03:38 PM Re: check reconciliation report missing pennies [Re: Carol Lord Openhym]
FYI, I downloaded my client's data, ran it against AP 8.1D and the "cents" now appear. Thanks for fixing this, guys, needless to say, this has been a hassle for them and they'll be most grateful!
Carol
Carol Lord Openhym
Baltimore, MD USA
2 registered (Carol Wojick, Warren Karges), 623 Guests and 3 Spiders online.
14567 Topics
