#30354 - 01/04/12 11:29 AM A/P print problems
Mabel Offline
I have A/P 8.1C and having problems printing. I print my manual check batch and all goes well. I attempt to print check audit list and check reconciliation and I get this error message: System error, Code 1722. the RPC server is unavailable.
Mabel
NNFC
250-627-8486
#30360 - 01/04/12 12:27 PM Re: A/P print problems [Re: Mabel]
Hi Mabel,
That error message is not being returned by Adagio. Do you get the same error if you Preview these reports rather than print? How about when printing to a different driver, such as the AdagioPDF printer? If not, the problem is with your printer.
When I Googled the entire error message, I found many references to this and they were related to print spooler problems.
#30366 - 01/04/12 01:59 PM Re: A/P print problems [Re: Softrak Support]
Mabel Offline
I checked the spooler in Control Panel, Services to ensure that it is ok. Tried printing again and same problem. I can print one item and then when I try to print again, error message says "Access violation at address 00839D10 in module 'APWIN.exe'. Write of address 0000005D. It freezes up and i must soft boot to get out. The only thing done differently was a Windows update at the end of the day yesterday. I have Lexmark E360dn printer.
#30367 - 01/04/12 02:22 PM Re: A/P print problems [Re: Mabel]
Mabel Offline
The problem is fixed. I shut the power off on the printer and then the printer icon showed up on bottom taskbar and I deleted the print jobs.
