Hello again, Margo
YES YES YES
None of the files associated with running Adagio should have a Read Only attribute, this includes your data files!
In a nutshell, the Softrak folder, it's sub-directories and all the files within should (if anything) only have an Archive attribute. As well, this would include the following folders and all their contents:
- QRASP (usually found on the same drive as the ASP folder).
- Crystal (found under the Windows directory).
Since you are using Adagio with ACCPAC, then the other files Adagio uses in the ASP folder, the currency files (mc*.*) should also be checked.
To find out all the folders and program files involved, you can open the install.log and/or install.txt files (they are text files) to see what files are installed by Adagio. Check them to ensure that none are Read Only.
On another note, since you are running W2000 - Adagio must be installed while logged on as the actual User of the station, and this User must have full administrator rights during any type of Adagio install.
Hope this helps!
