#29497 - 10/27/11 02:03 PM setting default Gridview workspace for each user
AKFP1963 Offline
Stranger
Loc: NJ
Getting the error message Unable to Open Workspace when I try to set up the default workspace by editing the target property in Gridview as follows:
G:\Softrak\GVWIN\GVWin.exe /wU:\Users\CAndrews\Reports\AKFPVendorInquiry.gvs/dg:\adagiodata\cadata.fdc /efdc /uCA /pcarrol
program location\program /wFile location\workspaceName /dg:\datalocation\data /dataExtension /uUser /password
Is there anything wrong with the way I'm setting up the default workspace?
#29498 - 10/27/11 02:30 PM Re: setting default Gridview workspace for each user [Re: AKFP1963]
Assuming you copied the string from your shortcut, first try putting a space between the workspace name and the /d for the data path. Without the space, the app is reading the data path as part of the workspace name.
#29500 - 10/27/11 02:53 PM Re: setting default Gridview workspace for each user [Re: Softrak Support]
AKFP1963 Offline
Stranger
Loc: NJ
It worked. Thanks.
Only confirms that we all need some space from time to time! smirk
