Page 2 of 3 < 1 2 3 >
#29320 - 10/13/11 02:35 PM Re: how to enable import in AP, GL, and OE [Re: Michael2011]
When you copy the batch in Ledger, you can globally change the reference and/or either description. This change was added in Ledger 9.0D.
#29321 - 10/13/11 02:52 PM Re: how to enable import in AP, GL, and OE [Re: Michael2011]
Michael:
OK, so rather than entering AP Invoices and OE Invoices through the Adagio interface, your preference would be to import them. Correct? You've had success with that in GL but it's harder to make an argument for it in AP and almost impossible in OE.
They are more complex imports because there are more things to verify (vendor codes, document numbers, item numbers, distribution codes, inventory locations, ship to codes etc). That means there are more reasons for the import process to fail, leading to frustration. And in OE, the number of lines varies between orders. The OE Import process was really created for instances where orders are created externally (ie. from a web-store).
I wouldn't recommend doing this, but if you want to try it out, you will have to locate the appropriate templates in Adagio's Sample data (you cannot export invoices from AP or OE). The files are:
AP = X:\SOFTRAK\APWIN\SAMDATA\APINVIM.CSV
OE = X:\SOFTRAK\OEWIN\SAMDATA\OEORDIM.CSV
(where X: = your Adagio drive letter)
A a general rule, try to remove the unnecessary elements to simplify the file. I would recommend asking your Adagio consultant to help you at that point (although he or she may try to talk you out of doing this at all grin )!
#29322 - 10/13/11 03:03 PM Re: how to enable import in AP, GL, and OE [Re: Retired_Guy]
Michael2011 Offline
Adagio Groupie
Loc: BC
Thanks, Andrew.
the fact is that we prepare the month-end journal entry in Excel anyway, so it is natural to work in excel and import the csv file when ready.
Thanks for the info on global change of info inside ledger, I am sure I will find it useful some time.
#29323 - 10/13/11 03:22 PM Re: how to enable import in AP, GL, and OE [Re: Bruce Gardner]
Michael2011 Offline
Adagio Groupie
Loc: BC
Andrew:
Yes, you understand me well.
And, I understand your point as well.
For AP, I only want to use import for the things that are repeated every month, such as payroll for certain employees, lease, certain goventment remittances. all other non-recurring items will go through the normal input procedure.
and for OE, it is a similar situation. we are a non-for-profit association.we do four or five conferences each year. when we invoice members for the conference fee, every invoice have the same info, differences are customer id, amounts etc. and all these info are in csv format already(generated by event registration database). so importing from csv will save lots of time. Of course, we will manually enter invoices that are non-recurring.
I have located the APINVIM.CSV, but can not find OEORDIM.CSV.
Is there a way that you can send one to me?
Many thanks.
#29324 - 10/13/11 03:23 PM Re: how to enable import in AP, GL, and OE [Re: Michael2011]
Ok. I understand. It's just that your original post said that you were exporting, changing and then importing the JE.
#29325 - 10/13/11 03:49 PM Re: how to enable import in AP, GL, and OE [Re: Retired_Guy]
Hi Michael,
OrderEntry does not have a sample import order file named as above, but rather 6 different files - related to the 6 different default templates. They are named 'OEORDER#.csv' where # is the digit from 1 to 6. There are actually 6 more files 'OEFIXED#.TXT' which are 'fixed format' import files.
Note that OrderEntry only allows importing orders and not invoices, so this will be a two-step process - import the order and then manually edit each one to create an invoice. You may be better off using the Copy Order function (or Restore History invoice) to generate these. Or if you don't really need order processing and just want to create and print invoices, then perhaps Adagio Invoices is a more appropriate fit, with it's built-in recurring batch process.
Adagio Payables has a Recurring Batch process as well - I presume that you would rather maintain this sort of entry in Excel or CSV files anyway.
If you pursue the Import route, ensure you check out the Help file for import notes to see the effect of including or excluding particular fields in a template.
#29326 - 10/13/11 04:10 PM Re: how to enable import in AP, GL, and OE [Re: Retired_Guy]
Michael:
Likley you don't have the Order Entry module so you may not find the OE*.CSV file in your sample data. If you do not need to print invoices from Adagio then you may only need to import the invoices into Receivables.
By the sounds of it you are doing a lot of things manually in spreadsheets. Often this is not the most efficient way to get transaction into any accounting database, unless the spreadsheets are exported from an external application and imported into the accounting applicable without further manual processing.
A good Adagio consultant should be able to help you sort all of this out. If you are not currently working with one please give me a call.
#29332 - 10/14/11 08:19 AM Re: how to enable import in AP, GL, and OE [Re: Douglas Dickie]
Michael2011 Offline
Adagio Groupie
Loc: BC
Thanks for your comment, Softrak Support & Douglas.
1. We are using OE, and I did find 'OEORDER#.csv' and 'OEFIXED#.TXT' and I will study them in detail.
I checked OE help, and there is not much on “effect of including or excluding particular fields in a template”, can you send me a pointer on where to find more in depth info.
2. Andrew’s point on manual processing is well taken. After each conference that we held, the database will generate an excel list of 400 or so attendee names with the amount due. I have tried to use recurring batch and copy invoice before, but I will have to go in to every one of the 400 orders and change the item from 2010 August Conference Fee to 2011 August Conference Fee. In excel it takes no time at all to make that kind of change.
I understand our situation is unique, in that we generate invoices in “batches”, and with each “batch”, hundreds of invoices are almost identical, except the customer name and amount. I am hoping that importing from a csv or txt file will solve our problem.
3. We are using OE to print invoice right now. What is the difference between OE and adagio invoice? When should we use Invoice instead of OE?
Thank you!
#29334 - 10/14/11 09:01 AM Re: how to enable import in AP, GL, and OE [Re: Michael2011]
Hi, Michael,
On our website (www.softrak.com), point at Training at the top of our homepage and select ShowMe How! Technical Videos and Documentation. Then, select Documentation and, on the right side, select the Import and Export TechTips. You'll find detailed information on Importing Orders and Special Prices in OE (along with import and export information for many other modules).
#29335 - 10/14/11 09:08 AM Re: how to enable import in AP, GL, and OE [Re: Softrak Support]
Hi Michael
I am appending a page I wrote for the Adagio Consultants Handbook that discusses the differences between OE and Invoices.
OrderEntry
OrderEntry is the best option for companies, such as distributors or wholesalers, who
enter sales orders, and at a later date generate invoices. It alone can easily track the
status of backorders and record partial shipments.
OrderEntry has the following advantages over Invoices:
• Integration with the quote function in SalesCQ (although Invoices Archive
Batches can be used to store and manage quotes)
• Integration with UPS or FedEx
• Integration with EDI and with webstore software such as Virtual Vendor
• Integration with Purchase Orders for Adagio, so that PO’s can be created from
an OE sales order
• Powerful built-in “customer by item” and “item by customer” inquiries
• Direct integration with Inventory; Invoices requires that you import shipments
in order to relieve inventory. OrderEntry updates quantities in Inventory in real
time.
• Ability to modify text fields in an already posted invoice
• Label printing
Invoices has the following advantages over OrderEntry:
• Ability to print, modify and reprint an invoice prior to posting
• Posts directly to Receivables without need for a clearing account in Ledger
• Ability to include up to 10 lines of 75 characters per invoice item
• Multiple detail “styles” on one invoice
• Ability to mass update recurring (archive) invoices
2 registered (Jesse_Gilbert, Bruce Gardner), 169 Guests and 4 Spiders online.
14577 Topics
