#29063 - 09/27/11 05:31 AM DataCare BackUp Doesn't Work Anymore
DataCare 9.0A (110324) was working most of the time up until Sept 15. Now every night when it runs on schedule, it creates 2 back up files instead of one. DCB1865.ZIP & DCB1865.Z01. I cannot open or use either file. I've tried repeating the back up many times but it keeps doing the same thing. I have confirmed that there are no other processes running while the back up is running. I shut the computer down and restarted, but still have the same result. I tried it from another workstation and it worked successfully. Not sure what the problem could be. I guess I'll have to run DataCare from the other workstation since I can't get it to work anymore from this one. Very frustrating that DataCare reports a "success" regardless of whether it's actually a success. It has to be manually checked every day or you might think you're getting back ups when you're not.
#29064 - 09/27/11 05:37 AM Re: DataCare BackUp Doesn't Work Anymore [Re: SusanTennier]
Hello Susan,
How big are the two *.z?? files, and how big is the dataset you are trying to back up? Also, how much free space exists on the target drive for the backup, the drive with your Adagio data, and the local C:\WINDOWS\TEMP drive?
I understand the frustration. This might take some time to track down.
#29067 - 09/27/11 06:18 AM Re: DataCare BackUp Doesn't Work Anymore [Re: Retired_Guy]
When the back up was working successfully, the .zip files were consistently around 280,000 KB. Last night the unsuccessful .zip is 178,000 KB and the .Z01 is 103,325 KB. The night before the unsuccessful .zip was 234,000 KB and the .Z01 was 46,000 KB. Every night they are different but the 2 files add up to around 280,000 KB.
The data we are backing up is 2.83 GB.
The drive where the back ups are located has 104 GB used and 44 GB available.
The drive where Adagio is located has 177 GB used and 70 GB available.
C:\Windows\Temp has 2.92 GB in it.
#29072 - 09/27/11 08:21 AM Re: DataCare BackUp Doesn't Work Anymore [Re: SusanTennier]
Ralph Allan Offline
The .Z01 (and .Z02, .ZA03 ...) files are created by the zip program when it senses that the backup would result in a file that is larger than the largest file that can be stored using the file system on the target drive.
If you are backing up to a regular hard drive using the NTFS file system, this is about 4 gb.
If you backing up to some other device, like a USB "stick," it may be much smaller.
Try redirecting the backup to a different device if you wish to avoid this.
WinZip should be able to deal with the multiple files, just open the .ZIP file and it will read the other files as needed, provided you keep them together in the same folder. (You will notice that .ZIP file time is slightly later than the other files; it was created last and contains the listing of the other files.)
Ralph Allan
Business Computer Centre
Prince George BC Canada
#29077 - 09/27/11 09:20 AM Re: DataCare BackUp Doesn't Work Anymore [Re: Ralph Allan]
The drive we are backing up to is NTFS and since the .zip file is only around 1/4 GB, reaching the maximum size of 4 GB shouldn't be an issue. We are backing up to the local computer C: drive in a folder called backup. Not using a USB stick or any other external type of memory. No luck opening the .zip file.
#29105 - 09/29/11 06:02 AM Re: DataCare BackUp Doesn't Work Anymore [Re: SusanTennier]
I deleted the Windows/Temp contents and some of the old back ups in C:\backup and the result was a successful back up last night. I only wish that DataCare would report the failures because otherwise I have to check this EVERY DAY to see if it was really successful.
#29111 - 09/29/11 10:34 AM Re: DataCare BackUp Doesn't Work Anymore [Re: SusanTennier]
I have this happening in many clients that have .zip files between 150MB and 600MB. It doesn't happen all the time but we cannot rely on that backup anymore. It doesn't happen with the Toolkit backup. Is Datacare and Toolkit creating the .zip files with the same tool?
#29123 - 09/29/11 02:39 PM Re: DataCare BackUp Doesn't Work Anymore [Re: Patricia B.]
Ralph Allan Offline
I do not see why this is a problem. Even if the ZIP program splits the backup into multiple files, it can still unzip (restore) any or all of them. Just use WinZip (or similar utility) to open the .ZIP file and it will find the files in the other files.
Ralph Allan
#29124 - 09/29/11 02:43 PM Re: DataCare BackUp Doesn't Work Anymore [Re: Ralph Allan]
Ralph:
You are assuming that DataCare intentionally split the file using WinZoip standard.In this case it is a failure of DataCare to complete the zip file creation (leaving the temp file).
#29130 - 09/29/11 03:14 PM Re: DataCare BackUp Doesn't Work Anymore [Re: Douglas Dickie]
No luck opening those .zip files.
1 registered (Softrak Support), 74 Guests and 1 Spider online.
1865 Members
14452 Topics
