#28799 - 09/07/11 09:13 AM ODBC Connection Errors after Upgrade
Lucas Offline
Loc: Vancouver, B.C., Canada
Hey everybody,
this is a continuation of this thread.
It seems that ODBC is not connecting after an upgrade. It keeps giving me a "File none, Line 586" error.
I followed the following instructions from Bruce:
Quote:
Adagio's installation process saves the previous files as a precaution. Look in \Softrak\OEWIN\Backup\YYYYMMDD where YYYMMDD should be 20110903 in your case.
Get everyone out of Adagio
Go to \Softrak\OEWIN\Backup\20110903
Copy ADS32.dll (confirm that it is an older version)
Go to \Softrak\System
Rename the existing ADS32.dll to ADS32.new
Paste the older one
Test your ODBC connection
If the problem remains, reverse this process
Note that ADS32.dll is a critical file for Adagio. If you are uncomfortable with these steps or the process of reversing them (if necessary), ask for support from your Adagio consultant.
Now, my file wasn't found in OEWIN but in RPWIN and also the backup to Lanpak. When I tried replacing the file with each of them the same set of problems occurred:
1.) ODBC will not give the error, but it prompts me for a U/P which I cannot give a correct answer to. It then cancels the operation
2.) No other module is able to access Lanpak. It says Invalid sign in or something similar.
Any other ideas?
thanks!
Lucas
#28800 - 09/07/11 09:48 AM Re: ODBC Connection Errors after Upgrade [Re: Lucas]
Michael Mulrooney Offline
You should never copy ADS32.DLL..
There are times when a given version of an Adagio product relies on a particular version of ADS32 being present, if it is not there the results are undefined!
No LANPAKS for example.
Replace the ADS32.DLL with the newest version from July 21 2011 and your Lanpaks should start working once more.
Download
http://www.softrak.com/dbr/upload/May2011ODBC.zip
This file has 3 files which should replace the files with the same name in ..\Softrak\ODBC
Save the originals before overwriting.
#28802 - 09/07/11 09:50 AM Re: ODBC Connection Errors after Upgrade [Re: Michael Mulrooney]
Lucas Offline
I already replaced ADS32.dll with the newest file and it went back to the original functionality.
What are these files and why was this kind of thing not published as a Service Pack?
What is the password for this zip file?
Edited by Lucas (09/07/11 09:53 AM)
#28806 - 09/07/11 02:34 PM Re: ODBC Connection Errors after Upgrade [Re: Lucas]
Lucas Offline
This worked perfectly.
Thank you everybody. This file should be turned into an ODBC Service Pack.
#28977 - 09/21/11 10:28 AM Re: ODBC Connection Errors after Upgrade [Re: Lucas]
Johnd Offline
Loc: Montreal
We are experiencing this same problem with ODBC after the upgrade for Lanpak and Ledger. Where can I get the password for the zip file?
#28979 - 09/21/11 11:13 AM Re: ODBC Connection Errors after Upgrade [Re: Johnd]
John has received the files
0 registered (), 79 Guests and 2 Spiders online.
1866 Members
14518 Topics
27 28 29 30 31
