#288 - 11/10/99 07:17 AM QR 6.5 missing report table -OE600
We recently upgraded from QR 6.1F to 6.5 (990428). Most of the reports already defined works with the new upgrade. Except for one report which is based on OE 6.1B.When tried to open the message "Report table OE600 not found, use install data" appears. Even after installing the OE the message still exists. Pls help..
#289 - 11/10/99 12:18 PM Re: QR 6.5 missing report table -OE600
Hi Devon,
The reason you are receiving this error message is that this report was written with the OE6.00 version table for Quik Reports. Because you have OE6.1B, you require to have this version of the table tagged in Install Data.
To fix this, you have to do a cross-table conversion as described in Ch 11 or in the release notes. Basically:
- Tag the OE600 table in Install Data
- Open your report, save it and close it
- Set table to OE61B in Install Data
- Set Convert Reports = Y from Options/Configure
- Open the report and convert it
- Set Convert Reports = N
14672 Topics
