#28629 - 08/26/11 10:15 AM Datacare errors do not match IC DIC
IC 8.1C 20110713
DIC in Inventory Control doesn't show any errors.
Datacare 9.0A 20110324 run on the same database, shows multiple errors for each of the following examples:
"BOM Master item XXX XXXXXX, BOM 66, line 1, component YYY YYYYY is not active" False error, Component is ACTIVE.
"Item F82 14733 has orphan history records" Seems to be correct because the item doesn't exist.
It seems to me that Datacare and IC are not in sync. I will not be able to run IC on the Datacare job until this issue is solved. Please, let me know when.
#28636 - 08/26/11 12:54 PM Re: Datacare errors do not match IC DIC [Re: Patricia B.]
Hi Patricia,
We can't do much about this without a copy of the data to verify what the problem might be. Please upload to Softrak in the usual way and the investigation can continue off-line. We are not aware of any integrity check problems.
#28637 - 08/26/11 12:58 PM Re: Datacare errors do not match IC DIC [Re: Patricia B.]
Brian Stief Offline
Waterloo Guy
IC 8.1 20110713 update
We just started seeing this identical message in Datacare on a client's data for 2 nights running since upgrading the IC to the July 13 version of 8.1C, this week. Checked out the data this morning.
Rebuilding the data doesn't do anything. Rerunning Datacare shows same message.
So we tried DIC in IC, and it says it's clean. Checking the BOM line item entry in IC says it's active. So agree with Patricia, it must be a false error.
Please advise.
Brian
Brian Stief,CPA,CA
800.540.3164
#28639 - 08/26/11 01:24 PM Re: Datacare errors do not match IC DIC [Re: Brian Stief]
When IC 8.1C was released, a new filed for Active Item was created. I think Datacare is checking that field instead of the new one. I wanted to verify this theory but the field is not available in the dictionary any more.
#28646 - 08/26/11 03:00 PM Re: Datacare errors do not match IC DIC [Re: Patricia B.]
Using the current release of Adagio Inventory 8.1C (2011.07.13) where Bill of Materials are defined, I cannot replicate the situation with sample data where DataCare reports false errors on the active status of component items. Also, if a component item is marked with the inactive status, I do get this 'warning' in the integrity checks within Adagio Inventory:
BOM Master item aaa.aaa-aaa, BOM bbb, line 4, component ccc.ccc-ccc is not active.
Note that this is a 'warning' and not an 'integrity error' that requires fixing. If there is a concern that Adagio DataCare is not reporting the 'application warning' then I can forward this to development, but the integrity of the data is in fact clean.
If you want to check the Active Item status of an IC Item, this field is available on the column editor - the first one if you sort the field list alphabetically from User Preferences. This field was not removed from the dictionary. If you find that any items have a 'blank' value for Active Item, then this is an error - likely caused by using an older version of Purchase Orders for Adagio to create items.
Edited by Andrew Bates (08/26/11 04:13 PM)
Edit Reason: Fixed typo - s/b inactive
#28650 - 08/26/11 04:05 PM Re: Datacare errors do not match IC DIC [Re: Softrak Support]
The Active Item contains an "A". The false warning distracts the attention to real errors happening in Datacare.
#28651 - 08/26/11 04:15 PM Re: Datacare errors do not match IC DIC [Re: Patricia B.]
We still need the data. We're not getting the same results here.
#28663 - 08/29/11 10:49 AM Re: Datacare errors do not match IC DIC [Re: Retired_Guy]
Thank you for the data. Indeed DataCare 9.0A is reporting that 10 particular component items are inactive in it's integrity check, where the check within Inventory is reporting as clean. There are 6665 component items that are not reporting the same error, so we will continue investigation as to what it is with these particular 10 items that are giving the error in DC.
#28664 - 08/29/11 11:19 AM Re: Datacare errors do not match IC DIC [Re: Softrak Support]
Hi Patricia,
Just found something interesting with this data. The 10 items that appear on the false DataCare DIC errors (and no others) were edited by user DD on Dec 21, 2010 around 1:20PM. If you can indentify who user DD is and what changes they made, that could indicate that whatever they did made a change to the items that is causing the errors in DataCare.
#28672 - 08/29/11 03:15 PM Re: Datacare errors do not match IC DIC [Re: Softrak Support]
The items were deactivated on Dec 21,2010. Datacare showed that those components were not active and rebuilt the "errors" automatically activating the components (undesirable status). The message did not show up in Datacare 8.1A anymore. However, the errors show with Datacare version 9.0A (that was installed at the same time) without the IC service pack. Unless, something is already installed in the local workstation that doesn't allow me to recreated the environment without the IC Service Pack.
If I open the Items table with @N80AITM dictionary, it shows the Active Item field with an I and all the Active Records show a blank.
If I open the Items table with @N81CITM dictionary, it shows the Active Item field with an A.
Does it mean that there are two Active Item fields and now Datacare is checking the old one?
0 registered (), 136 Guests and 2 Spiders online.
14667 Topics
