#28502 - 08/18/11 09:53 AM Importing Departments into GL
KNoel Offline
Loc: Ottawa ON Canada
Is there any way to import new department codes and descriptions we currently have in Excel?
Karin
#28504 - 08/18/11 10:15 AM Re: Importing Departments into GL [Re: KNoel]
Michael Mulrooney Offline
In the G/L look at File | Import | Departments
#28505 - 08/18/11 11:03 AM Re: Importing Departments into GL [Re: Michael Mulrooney]
Are you also trying to set up the necessary account / departments for each of the new codes? If so, it might be easier to copy an existing department to the new department code, which will create all the necessary records for you.
#28547 - 08/22/11 05:12 AM Re: Importing Departments into GL [Re: Retired_Guy]
KNoel Offline
I'm using GL 9.0C (110131) and don't seem to have a File | Import | Departments option. That would have been so easy!
Andrew, these are all new departments. The account portion is already existing. To give you some background, we are importing a second company's data on a monthly basis for reporting into a new "consolidated" company and would like a way to import this second company's department descriptions for reporting. This is a first step at eventually moving towards using FX but the process is working well other than not having dept descriptions for this second company.
Any suggestions would be much appreciated!
Karin
#28553 - 08/22/11 08:05 AM Re: Importing Departments into GL [Re: KNoel]
Upgrade to Ledger 9.0D where File | Import | Depertments is available.
#28578 - 08/23/11 07:27 AM Re: Importing Departments into GL [Re: Retired_Guy]
KNoel Offline
Woohoo!!
We're in the process of upgrading, but having a few issues...I'll let you know if this solves our issues!
Karin laugh
#28579 - 08/23/11 08:36 AM Re: Importing Departments into GL [Re: KNoel]
Those would be "departments"!
But you need to understand that adding a list of departments does not automatically add the accounts associated with those departments. That is done with the "Copy Department" function.
There is an option in the Company Profile to generate an integrity error if an account-department pair does not have a proper department record. You might want to make sure that option is on.
0 registered (), 130 Guests and 0 Spiders online.
1869 Members
14601 Topics
