#28334 - 08/09/11 12:57 PM
IC 8.1C Item Valuation Report
Since the Service Pack to IC 8.1C (110713), the Item Valuation Report is giving us an error.
"Error Floating point overflow occured when attempting to append record to I/C Valuation Report Temp File".
See .jpg attached.
Item Valuation.jpg (109 downloads)
#28337 - 08/09/11 03:00 PM
Re: IC 8.1C Item Valuation Report
[Re: Softrak Support]
Integrity check runs through without errors.
The error only occurs when I date it back to March 31, 2011 which is the last day of our last fiscal year. After the error, the report completes, however, it's showing almost $20,000 in residual costs, that I know for sure was not there as of March 31, 2011.
Sort by item number starting at first and ending at the last item.
#28368 - 08/11/11 07:57 PM
[Re: SusanTennier]
After day end today, I checked the Inventory balance in Ledger and compared it to the Item Valuation Report. Ledger was up $1.14. Yeah!
Then I dated the Item Valuation Report back to July 31 and compared it to the Inventory balance in Ledger on July 31 and Ledger is down over $29,000.
Then I dated the Item Valuation Report back to June 30 and compared it to the Inventory balance in Ledger on June 30 and Ledger is down over $16,000.
Then I dated the Item Valuation Report back to May 31 and compared it to the Inventory balance in Ledger on May 31 and Ledger is up over $21,000.
Then I dated the Item Valuation Report back to April 30 and compared it to the Inventory balance in Ledger on April 30 and it crashed "Error Floating point overflow occured when attempting to append record to I/C Valuation Report Temp File".
I tried dating the Item Valuation Report back further (i.e. March 31) but it also crashes.
I was hoping for a fix to the problem of not being able to back date the Item Valuation report. Without back dating, it makes it very difficult to balance IC to Ledger and provide the accountant with a report to show they balance as of year end. There seems to be ongoing major problems with this report related to back dating. As it stands now, I don't think anyone should attempt to back date the Item Valuation report if they are wanting accurate results. There are also some crazy residuals reported with back dating that don't make any sense.
Please let me know if this is being looked at and if and when it will be fixed.
#28494 - 08/18/11 05:51 AM
[Re: SusanTennier]
Can someone at Softrak let me know if you acknowledge that back dating IC Item Valuation is not working and let me know when to expect a fix?
#28518 - 08/18/11 04:37 PM
It doesn't even almost work when back dating on mine. Back date to the last day of the previous month and I get 2 pages of residuals that are not actually there. Also the balance is way off from Ledger. Did anyone try it and if so, did it balance with Ledger?
What sample data can I use to test this? The sample data in IC and Ledger both say the fiscal year is 2007 when you open it in Ledger and there are a number of batches to retrieve and post. To test this, I need some current data where the day end has been done and all batches retrieved and posted in Ledger.
1 registered (Bruce Gardner),
163
Guests and
Spider online. |
14578 Topics
