#28342 - 08/10/11 09:48 AM Windows not able to resize
Marianne Offline
Accounts Payable
Loc: Surrey, BC Canada
Windows 7's default window is SMALL and this is what ADAGIO works with. When changing to MEDIUM, the ADAGIO windows don't show up all the fields properly...they are overlapping. The windows won't stretch to show up or adjust the fields automatically, so I have to live with a SMALL windows. This is so hard. I have to suffer from doing all my other works just to accomodate the windows designed for the new Adagio. Is there a fix for this?
#28346 - 08/10/11 02:31 PM Re: Windows not able to resize [Re: Marianne]
Hi, Harpo,
I'm using Windows 7 and I don't experience these problems. Mine is set at Smaller and I don't have this problem. My DPI settings are also set to 96 pixels per inch. I happen to have Windows XP-style DPI scaling enabled. My Resolution is 1440 x 900.
#28349 - 08/11/11 07:09 AM Re: Windows not able to resize [Re: Softrak Support]
Marianne Offline
Accounts Payable
Yes, it has no problem with resolution set to SMALL (default). The problem occurs when you set your windows resolution to MEDIUM or larger. The problem with smaller resolution is working outside ADAGIO. It's hard to see...
#28350 - 08/11/11 07:11 AM Re: Windows not able to resize [Re: Marianne]
Marianne Offline
Accounts Payable
Try to change your windows resolution to medium and see yourself what I'm saying when you work in the Ledger.
#28352 - 08/11/11 08:06 AM Re: Windows not able to resize [Re: Marianne]
When you change the font size to "medium" under Windows 7, make sure you DISABLE the check box to use XP style scaling. Alternatively, instead of playing with the fonts, just reduce the resolution of your screen (which is what changing the font size under Windows 7 does anyway).
#28353 - 08/11/11 08:21 AM Re: Windows not able to resize [Re: Retired_Guy]
Marianne Offline
Accounts Payable
Hi Andrews,
Yeah it works! It looks like a little blurry though working on Adagio environment when the Windows size is set to MEDIUM. But, I can live with it.
Thanks.
0 registered (), 206 Guests and 7 Spiders online.
14576 Topics
