#28288 - 08/05/11 12:08 PM Financial Reporter Stopped Working
Marianne Offline
Accounts Payable
Loc: Surrey, BC Canada
So far, I did run the SysUpdater and it didn't fix the problem. I'm running Ledger 9.0D version. Please reply asap. I'm behind now with my July month end and needs this fix asap.
#28289 - 08/05/11 12:25 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Hi, Harpo,
Resolving problems of this nature can be difficult over a forum. It may be best for you to contact your Adagio consultant who will be able to help you more in person.
#28291 - 08/05/11 12:43 PM Re: Financial Reporter Stopped Working [Re: Softrak Support]
Marianne Offline
Accounts Payable
Isn't it software problem from new release upgrade? Even a consultant cannot resolve the issue if the fix is not released yet from software developer. If the fix can be provided by the consultant, yes I will go to them.
#28295 - 08/05/11 01:22 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Hi, Harpo,
We haven't identified that there is a problem with the software in this particular instance. Others are running GL9.0D and are not experiencing this after installing the SysUpdater. You haven't indicated exactly what happens when you try to run the Financial Reporter or if there is any error message(s) being received.
However, I notice you have two different threads open on this forum, both about the same issue. We will be responding to this thread now only. From the other thread, it seems you are using the correct ADS32.dll.
Your consultant might be better equipped to troubleshoot the problem with you in your office. Overall, it might be faster.
If you close Ledger completely and drill down to your data folder, look for the file GLRPTGRP.xxx (where 'xxx' is your 3-character data extension). No one else should be using Ledger when you do this. Rename (don't delete) the file, perhaps to something like GLRPTGRP.xxx.harpo. The file will be recreated when next you run the program. You will need to recreate any Statement Groups you had previously set up though.
When next you open Ledger and try to run the Financial Reporter, can you?
#28296 - 08/05/11 01:36 PM Re: Financial Reporter Stopped Working [Re: Softrak Support]
Marianne Offline
Accounts Payable
The message says, "Adagio Financial Reporter stopped working" Windows can check online for a solution to the problem. I've seen this error from other posts, but it's for LanPack 9.0D. Do you think it's the same with this Ledger error?
#28297 - 08/05/11 01:41 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Marianne Offline
Accounts Payable
Below is the problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: LEDGERFINREP.EXE
Application Version: 2.1.1.1839
Application Timestamp: 4e31e2c6
Fault Module Name: LEDGERFINREP.EXE
Fault Module Version: 2.1.1.1839
Fault Module Timestamp: 4e31e2c6
Exception Code: c0000005
Exception Offset: 0004f080
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
#28298 - 08/05/11 02:00 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Marianne Offline
Accounts Payable
Do you think reinstalling the ledger would possibly solve the problem?
#28299 - 08/05/11 02:05 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Michael Mulrooney Offline
Most likely there is something wrong with your company data.
Open the "sample data" shipped with the product and see if you can start the Financial Reporter.
#28300 - 08/05/11 02:27 PM Re: Financial Reporter Stopped Working [Re: Michael Mulrooney]
Marianne Offline
Accounts Payable
Ok, sample data worked. And I found my financial statement too, but not by clicking the icon. I was able to open it after I opened the financial statement window and clicked our income statement from the directory.
#28301 - 08/05/11 02:28 PM Re: Financial Reporter Stopped Working [Re: Marianne]
Marianne Offline
Accounts Payable
Oh wait...when i closed the window...it automatically works now! Oh I'm so happy. The drive must have not been mapped properly.
0 registered (), 129 Guests and 3 Spiders online.
14584 Topics
February
