#27317 - 05/20/11 11:33 AM Runtime Errors in Financial Reporter
Lyndon_Olfert Offline
Loc: Winnipeg
I am currently getting Runtime Errors in Ledgerfinrep.exe
I am editing a statement spec and am getting a runtime error as well as an out of memory error.
Any ideas on why this would be? This is the first time I am trying to edit financial reports with Windows7.
The version of Ledger is 9.0C 110131 and the DIC is clean.
Lyndon Olfert, CPA, CGA, CAFM
#27320 - 05/20/11 07:05 PM Re: Runtime Errors in Financial Reporter [Re: Lyndon_Olfert]
Lyndon:
Does it happen on just that statement or all statements? At which point does it happen?
#27321 - 05/21/11 07:50 AM Re: Runtime Errors in Financial Reporter [Re: Bruce Gardner]
Loc: Winnipeg
It happens whenever I am in the Financial Reporter. It does not matter if I have a statement loaded. It also happens in safe mode. As soon as I open Financial Reporter the memory usage begins to climb until it crashes.
It only happens in this data set though, which is very odd. ADPROF settings appear to be correct.
Edited by Lyndon (05/21/11 07:54 AM)
#27322 - 05/21/11 08:13 AM Re: Runtime Errors in Financial Reporter [Re: Lyndon_Olfert]
Loc: Winnipeg
It is very bizarre. I cloned the company (excluding financial reports). Exported the batches from the old company to the new company. Everything now works normally now.
#27323 - 05/21/11 10:52 AM Re: Runtime Errors in Financial Reporter [Re: Lyndon_Olfert]
I'll bet one of the financial reporter support files was damaged.
#27324 - 05/23/11 08:36 AM Re: Runtime Errors in Financial Reporter [Re: Retired_Guy]
Michael Mulrooney Offline
As Andrew says this is, most likely, the result of a damaged file that is used by the Financial Reporter and not part of the regular DIC. If it is possible for you to upload the damaged data to www.softrak.com/dbr I will see if we can protect against this type of problem
#27385 - 05/26/11 11:09 AM Re: Runtime Errors in Financial Reporter [Re: Michael Mulrooney]
Softrak was able to duplicate the error, it was a damaged GLATREE file. Future versions of the Financial Reporter will detect and correct the error.
#27875 - 07/05/11 11:48 AM Re: Runtime Errors in Financial Reporter [Re: Michael Mulrooney]
How can I fix this error?
#27876 - 07/05/11 12:09 PM Re: Runtime Errors in Financial Reporter [Re: Patricia B.]
For now, remove the GLATREE data file and it will be recreated the next time the Financial Reporter is started.
