#270 - 11/02/99 04:39 PM QRW 6.2b & OE v.6.5
Can QRW 6.2B read OE 6.5? My dealer told me that it does. However, the compatability chart does not indicate that it does and I can not see it.
If it can, what needs to be done beyond the basic install to see the OE data files?
If it can not, is there a patch coming out? and when is it expected?
Thanks.
#271 - 11/02/99 05:44 PM Re: QRW 6.2b & OE v.6.5
The data structure did not change from OE6.1B to OE6.5A, thus there were no changes required for the table that Quik Reports for Windows uses in reporting. The table name will still say 'version 6.1B' but this will be just fine.
In creating new reports, you may have to 'uncheck' the List Installed Versions box as you have OE6.5A installed, but this should be the only issue you may run into.
In the next release of Quik Reports for Windows, the table name will be changed to OE6.5A, but that will be the only change to the table.
0 registered (), 150 Guests and 1 Spider online.
14672 Topics
