#26608 - 03/20/11 01:43 PM Re: IC Import Items Problem [Re: SusanTennier]
I'm thinking there has to be something wrong with the program since the upgrade. When I try importing as an Excel file I get this error, "Unable to access record in Option Fields Det Options". This record is in use by [symbols] in window [symbols]". And why might it be looking at Option Fields Det Options??
#26609 - 03/20/11 02:15 PM Re: IC Import Items Problem [Re: SusanTennier]
I can only import 10 records at a time. It works on 10 but not 20. But if you import 1 to 10 or 11 to 20 by themselves it works. I will be the rest of my life trying to import over 4600 items. 8(
#26610 - 03/20/11 02:18 PM Re: IC Import Items Problem [Re: SusanTennier]
doswalt Offline
Loc: AL
Susan,
Search the forum using +pick +seq +import. It should bring up a topic dealing with O/E that gives your exact error message.
The below is also one of the items and it deals with picking sequence by location (which changes a little in the new version).
http://www.softrak.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=25762&Searchpage=1&Main=6043&Words=%2Bpick+%2BSeq+%2BImport&Search=true#Post25762
#26611 - 03/20/11 02:38 PM Re: IC Import Items Problem [Re: doswalt]
doswalt Offline
Loc: AL
As an idea, I think what you are missing is the 'Location'. I think the newest Inventory 101104 uses a default location for inventory items.
****On some test data******* Modify a Physical Inventory worksheet to modify the Picking Sequence and attempt to import (not using any quantity fields in the import). This imports by Location. ****On some test data*******_
#26612 - 03/20/11 03:04 PM Re: IC Import Items Problem [Re: SusanTennier]
Susan:
I just exported 15,000 items to a CSV file (2 columns = Item #, Pick Seq), edited it to change some Picking Sequences and successfully imported it back in.
What version do you have installed? There's a Hot Fix dated Dec 24, 2010. It refers to solving an import problem with record-locking. Your Adagio reseller would be able to deliver that to you.
The message about the new item in the error log is normal. It just indicates that the process found a new item but skipped it since you have chosen to not import new items.
#26613 - 03/20/11 03:15 PM Re: IC Import Items Problem [Re: Bruce Gardner]
I need the hotfix!!
#26614 - 03/20/11 03:44 PM Re: IC Import Items Problem [Re: SusanTennier]
Okay, I have the hotfix from my Adagio consultant.. I will try it shortly.
#26615 - 03/20/11 04:34 PM Re: IC Import Items Problem [Re: SusanTennier]
THANK-YOU BRUCE!!!!!!! That was it.
A very long Sunday of work to complete one simple task.
Very happy to move past this.
1 registered (Warren Karges), 105 Guests and 5 Spiders online.
1869 Members
14601 Topics
