#26416 - 03/03/11 08:33 AM opening trial balance
Acrylon Offline
What's the easiest way to print out the opening trial balance of all my accounts for the fiscal year?
Thanks!
#26419 - 03/03/11 08:49 AM Re: opening trial balance [Re: Acrylon]
Hi, Cam,
Use the Financial Reporter. In fact, look in Ledger sample data for the GL!STRIAL.SAM statement. You'll have to copy it to your data folder and change the extension but it should provide a good example for you to work with. Of course, you'll also want to edit the account ranges to better match your own.
#26422 - 03/03/11 09:26 AM Re: opening trial balance [Re: Softrak Support]
Acrylon Offline
Worked great. One more quick question.
I'm using the formula =ADDRONLY("GLDATA.OPEN",$B9) to give me my opening balance. Cell B9 has the account. Some accounts have multiple departements. I have all the departments in column C. For example for account 1010-1 (where 1010 is the account and 1 is the department) I have "1010" in B9 and "1" in C9.
How do i tell the forumula to get the balance for that account-department combination?
Thanks!
#26513 - 03/08/11 05:11 PM Re: opening trial balance [Re: Acrylon]
Perhaps try replacing $B9 in the formula with $B9 & "-" & $C9, which would concatenate the account and department, and put a dash between them. The ampersand character in formulas is used to connect multiple text strings. Thus your formula would look like:
=ADDRONLY("GLDATA.OPEN",$B9&"-"&$C9)
#26514 - 03/09/11 06:31 AM Re: opening trial balance [Re: Softrak Support]
If you want the balance for all the departments (not specific ones) then place an asterisk ("*") where the departments are.
0 registered (), 156 Guests and 2 Spiders online.
14667 Topics
