#25840 - 01/20/11 05:00 AM Error Loading Rates
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
At a location the IT department did something to the server and changed a machine on the net work now I am having "Error Loading Rates" in Ledger they are using multi currency ...can you throw me a life line.. Thanks
Edward C Chin-Mook
876-754-7444
876-754-5513
#25841 - 01/20/11 05:38 AM Re: Error Loading Rates [Re: chinmook]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Hi Edward,
I’m sorry but I’ve never seen this error and I don’t have much experience with MC.
Having never received the specific error, your description below is a little too vague to zero in on specific troubleshooting methods. I think at this point there are more questions than answers:
- Is it a data or program problem ?
- Do you get the problem when using the Sample Data as well ?
- What are you actually doing when you get the problem ?
- Do you get the problem from all workstations ?
- “did something to the server and changed a machine” does that mean that they changed the server pc ?
- Can you run Adagio’s System Status utility (chksys) ? is it reporting any issues ?
Pete
Peter Banfield
BAMPH Consulting Services
Barbados
#25842 - 01/20/11 06:22 AM Re: Error Loading Rates [Re: BAMPH]
Chris McDonell Offline
Adagio
Loc: Vancouver, BC, Canada
Edward,
The 'Error Loading Rates' means that your currency files do not contain the currency/rate type the program is looking for.
The IT department has lost/changed the path to the currency files.
Currency files are/can be shared between databases and could be located in either \Softrak\System\ or if the client came from Plus \asp.
You might need to contact your local consultant to help get them back.
Chris
Chris McDonell
Softrak Systems Inc.
#25843 - 01/20/11 08:05 AM Re: Error Loading Rates [Re: Chris McDonell]
chinmook Offline
Loc: Jamaica
Which files do I check and edit to set the current adagio to where it should be.
Edward C Chin-Mook
876-754-7444
876-754-5513
#25844 - 01/20/11 08:52 AM Re: Error Loading Rates [Re: chinmook]
BAMPH Offline
Hi Edward,
In your data folder there should be an ADSPROF.xxx (where xxx is your specific company data extension or selector). If you view the file (notepad), in the [ADS] section you should see the line "Currency=...somepath..." and this is where the system expects the currency files (mc*.LD4) that the company is using to be.
It may just be that you need to correct the path in some way or maybe restore the files from a backup to the correct path.
Pete
Peter Banfield
Barbados
#25845 - 01/20/11 08:57 AM Re: Error Loading Rates [Re: BAMPH]
chinmook Offline
Loc: Jamaica
Thanks Bro
Edward C Chin-Mook
876-754-7444
876-754-5513
0 registered (), 243 Guests and 0 Spiders online.
14626 Topics
