#25544 - 12/24/10 12:57 PM
Re: Using payment method in O/E
[Re: Heather Mac]
Heather: Second Question: If you look at the first tab of the Company Profile in any of the modules, you will see the Home Currency in use. In the old ACCPAC Plus product, it used to default to a currency named "DOS". Of course this didn't make much sense as you would really be using $USD or $CAD. But that was the default and, as long as you were only using a single currency, no one noticed or cared. When you converted to Adagio, the same currency code was used. This sounds like what you are describing.
To enable multi-currency, you purchase the Adagio Multi-currency module.
At this point you have 2 choices: 1) Purchase a utility from Dakota Software that will allow you to change the currency from "DOS" to whatever you want (presumably "CAD"). This is the cleanest solution as the utility searches through all modules and makes a complete switch. See your dealer.
2) Keep "DOS" and use it to represent your true Home Currency (i.e. pretend that "DOS" is "CAD"). When you need to update the USD-CAD exchange rates, you will enter them as the conversion rates between USD and DOS.
#25574 - 12/30/10 10:20 AM
[Re: Heather Mac]
I'm pretty sure that's the way it has always worked, which is probably why no one has answered question 1. We're unsure what the question is.
#25582 - 12/30/10 11:24 AM
[Re: Heather Mac]
It comes in the invoice batch.
#25619 - 01/03/11 03:59 PM
[Re: Softrak Support]
Waterloo Guy
Hi Heather,
As noted above, the balancing of direct batches to cash entries in AR is really awkward, unless you use retrieval batches. So you must use retrieval batches or you will have difficulty balancing your cash processing with deposits.
Interfacing with Bank Rec from OE isn't an option right now, although works very well into a "Deposit Vault", say in Adagio Bank Rec. With this concept, you can process your OE payments into the Bank Rec Vault (via AR linking to the vault with the payment method), and do the bank deposit from the vault as a transfer into the actual bank account. Works very well with complete audit and processing trails.
If you are processing with POS or something equivalent, we have a Link2 POS solution that does the collection of the payment for the invoiced OE invoice, but is linked to the payment and collection by credit card, or debit or cheques. In any currency.
To clarify the above previous answers to converting to Multicurrency: This is not as simple as buying the Multi-Currency module and installing, unless you do not have any sales that are currently outside of Canada or you intend to start with new vendors and new customers with MC codes.
Most users would assume that you can just turn on a vendor or customer to start to be a MC account. This is not the case, so you should be aware that this is a complicated and costly conversion that should not be taken lightly.
While you can install MC module, and enable, it does not convert your existing data other than setting accounts to MC in your General Ledger.
There is no conversion utility other the old Accpac Plus utilities that will convert AR and AP, which leaves you with quite a problem with your OE, IC, PO's, Sales Analysis, and tax tables. While data in these applications is convertable, it is a major task to convert whether in Accpac, Adagio, or any windows accounting software solution.
You should talk to your Adagio Business Consultant or someone knowledgable about Multicurrency conversions, about the best way to approach this but be aware that this is not just a click a switch solution.
Talk to us if you still have questions.
Best, Brian
0 registered (),
342
Guests and
2
Spiders online. |
14666 Topics
