#25004 - 11/16/10 09:08 PM POA - Wrong Currency
Wayne Offline
Loc: Surrey
I set up POA with the wrong currency code, do you know if can it be fixed? The company had been set up years ago and was called ABC USA, so when I set up the POA I thought the currency was USD and it was CDN. They tried to retrieve to the ledger and had the problem. I can delete the POA and restart, but would be nice just to change the code from USD to CDN.
#25007 - 11/17/10 06:16 AM Re: POA - Wrong Currency [Re: Wayne]
I believe this is doable using GridView Read/Write.
#25008 - 11/17/10 09:55 AM Re: POA - Wrong Currency [Re: Steve Schwartz]
Bob Wisener Offline
Adagio Conductor
If you haven't entered any POs, you may be able to edit the home currency in the global file with a hex editor.
The Toolkit For Adagio has a function that will change the currency code across the dataset. It changes all locations where there's a currency code. For example PO lines and totals.
I'm assuming that multi-currency (multiple currencies with exchange rates) is not the case.
Bob Wisener
Dakota Software
