#24893 - 11/05/10 12:03 PM Financial Report
Barb9 Offline
Adagio Prodigy
Loc: Langley
In financial report maintenace showed option for currently year and last year(2 years). But would like to compare sales data for up to 5 years, is that anyway to do it?
Thanks.
#24894 - 11/05/10 12:21 PM Re: Financial Report [Re: Barb9]
Y, {1}Y, {2}Y, {3}Y, {4}Y, {5}Y.
#24921 - 11/09/10 10:23 AM Re: Financial Report [Re: Retired_Guy]
Barb9 Offline
Adagio Prodigy
Loc: Langley
Yes, it works. Thank you.
#24977 - 11/15/10 05:43 AM Re: Financial Report [Re: Barb9]
JulietBarrett Offline
jbarrett
Loc: Kingston, Jamaica
I posted my final audit entries in 2008/2009 data base. I exported it to 2009/2010.
However, the imported information is not reflected in the prior yr balance. It is relected as additional transactions for 2009/2010 period.
Kindly advise.
#24979 - 11/15/10 07:52 AM Re: Financial Report [Re: JulietBarrett]
Hi, Juliet,
First, what version of Ledger are you using? You can obtain this information by selecting Help and About from the main menu. It sounds like you maintaining 2008/2009 and 2009/2010 in two separate datasets so it may be that you are using an earlier version that Ledger 9.0x.
When you say you 'exported it to 2009/2010', I'm thinking you mean you imported it. Was this a batch you imported? If it was then posted to 2009/2010 rather than being Post to Prior year, it would be reflected as additional transactions for the 2009/2010 period. Are you able to use the Post | Unpost function to unpost the batch from 2009/2010 and then Post | Post to Prior so that it gets reflected in te prior year balance?
#24980 - 11/15/10 08:46 AM Re: Financial Report [Re: Softrak Support]
jbarrett
I am actually using 2 data bases. I do not have a problem in posting. Its just that when I import the info from 2008/09, there is some duplication.
Regards
#24986 - 11/15/10 02:31 PM Re: Financial Report [Re: JulietBarrett]
Hi Juliet
Please re-read Softrak Tech Support's reply and answer the questions that they ask.
0 registered (), 193 Guests and 6 Spiders online.
14577 Topics
