#24902 - 11/08/10 12:34 PM Lanpak issue? Cannot access device, path or file
Villla Cheryl Offline
Ptbo Gal
I am getting the following error message from computer B trying to access GL and A/Pay in computer A. "Windows cannot access the specified device, path, or file. Ypu may not have the appropriate permission to access the item. This has never occurred in the many years that I have been using Adagio, and I am not sure what to do. Please help!!!
#24905 - 11/08/10 01:31 PM Re: Lanpak issue? Cannot access device, path or file [Re: Villla Cheryl]
Hi Villa,
Are you aware of anything that has changed recently, such as upgrading workstations or the network, or anything else? Likely, the displayed error message is in fact the reason, that Windows/Network rights have changed so that the user of Computer B cannot see a required file, or a folder that contains the required file, or so forth.
Perhaps try running the \softrak\system\chksys.exe utility from workstation B, which checks the workstation setup settings and any missing or outdated files. After the initial run, click the button to check the read/write status accessibility of this workstation. It may point you to a particular location that this workstation cannot access.
This might be the type of issue that is best discussed with your Adagio consultant, as they can see and access your network and workstation.
1 registered (Bruce Gardner), 85 Guests and 1 Spider online.
14666 Topics
