#24039 - 09/20/10 08:13 AM PST field in PO
Acrylon Offline
We are using Purchase Orders for Adagio 8.1A (091029). The PST field displays the wrong numbers so we are wondering where the PST field is being pulled from.
Thank you.
#24041 - 09/20/10 09:22 AM Re: PST field in PO [Re: Acrylon]
Hi, Cam,
Tax statuses are set up in the PO Company Profile and should be the same as those used in Payables.
Tax groups are set up in the PO Maintenance function. It's here that you would determine the % tax charged for each jurisdiction.
Tax groups and statuses are assigned to vendors and to items. Adagio modules charge the lowest tax assigned. For example, an item might be taxable but if the vendor is exempt, no tax will be charged.
Similarly, if the vendor is taxable but the item is not, no tax will be changed on the item.
#24048 - 09/21/10 06:58 AM Re: PST field in PO [Re: Softrak Support]
Cam:
This issue is very dependent upon how you have your tax tables set up. Please call us if you need further assistance.
