#23740 - 08/23/10 09:35 AM
Adagio Receivables Windows 7 Installation Error
New Guy
Loc: New Jersey, US
(76.98.98.117)
I'm getting the message below when I try to install Adagio Receivables on a Windows 7 pro 32bit workstation. It installed fine on a windows xp machine.
"CRWIN Workstation Setup Error! When Adagio Receivables was installed, its Report Tables drive was specified as [F:] and was mapped to [F:]. However on this workstation drive [F:] does not contain a valid Report Tables for Adagio Receivables. Please check your workstation drive mappings and if necessary, reinstall Adagio Receivables"
I checked the drive mappings and they are correct(Drive F: is mapped to the F: drive on the server). I also tried using the server name instead of the IP address and no luck. Also, we are using version 8.1A which should work with Windows 7.
Any ideas? Thanks
Edited by sjglass (08/23/10 10:29 AM)
#23753 - 08/24/10 06:12 AM
Re: Adagio Receivables Windows 7 Installation Error
[Re: Softrak Support]
New Guy
Loc: New Jersey, US
(63.116.189.2)
I ran the Chksys and got the 1 error: "ERROR: No Report Tables drive for 32-bit products is defined for this User." This computer is brand new and this is the first time adagio has been installed. Actually, it won't install because I get that "CRWIN workstation setup error" before it can do anything. The user also has administrative rights and I also have tried running the setup as administrator within that user. As a workaround I installed it under windows XP mode, but I would like to get it working in windows 7 because they just paid for the upgrade allowing it to work in Windows 7. Any other ideas? Registry changes I might need to do?
#23758 - 08/24/10 07:27 AM
[Re: Douglas Dickie]
New Guy
Loc: New Jersey, US
(63.116.189.2)
We just paid for the upgrade to version 8.1A because the sales rep. said version 9.0 has too many issues and did not recomend it until the bugs were fixed. They did say version 8.1A was compatable with Windows 7. Which version of adagio requires you to turn off the user account control function? 8.1A or 9.0A? Or both? Sorry it was a little confusing. Thanks
Edited by sjglass (08/24/10 07:34 AM)
#23762 - 08/24/10 09:33 AM
New Guy
Loc: New Jersey, US
(63.116.189.2)
I'm trying to understand what you are saying, do you mean reinstall on the server level or just reinstall on the client workstation? I have not tried to reinstall on the server. I've tried to reinstall on the workstation, but the error stated before keeps me from doing so.
Thanks for your help
#23766 - 08/24/10 10:51 AM
New Guy
Loc: New Jersey, US
(63.116.189.2)
Let me just explain the setup that they have first. Not really sure if we are on the same page. They have a windows 2003 server with the full version of adagio receivables installed on it, including all tables, data, etc. We have two client workstations that run adagio. One workstation has Windows XP which works fine. The other workstation has Windows 7 pro. Adagio is installed on the F: drive on the server. The client workstations have the F: drives mapped to the F: drive on the server. From the mapped F: drive I go to the CRWIN folder and install adagio from the WKSETUP folder(I believe thats the location). Both workstations pull the data from the server. When I try tp install or reinstall from that location I get the error message. When I got the 8.1A update, I loaded it first onto the server and then updated the clients next. I don't really know what you are talking about when you say reinstall adagio program update from win 7 to the mapped drive on the server. It seems like it is going backwards since its coming from the server not the workstation. Maybe I'm backwards which is very possible. Also, I have tried to reinstall from the server to windows 7 workstation with the same error message.
Thanks again
Edited by sjglass (08/24/10 10:52 AM)
0 registered (),
194
Guests and
Spider online. |
1874 Members
14561 Topics
