#23648 - 08/18/10 05:14 AM Crystal Reports Install Error
Ryan Brohman Offline
I'm trying to install CR4A 8.5 to a Windows XP SP3 machine but am getting an error.
After entering the install codes and selecting the drives/paths (installed to C:\, report tables on network drive), I'm getting this error:
I have triple checked that the user is a member of the local administrators.
I've tried installing from the CD and the zip file. Version is (020328).
Ryan Brohman
Kitchener, ON
#23650 - 08/18/10 06:41 AM Re: Crystal Reports Install Error [Re: Ryan Brohman]
That's not the current version.
#23656 - 08/18/10 08:14 AM Re: Crystal Reports Install Error [Re: Retired_Guy]
Michael Mulrooney Offline
Perhaps try "Run as Administrator" on the Install which is different than running as a User who has administrator rights.
#23658 - 08/18/10 08:18 AM Re: Crystal Reports Install Error [Re: Retired_Guy]
When I attempted to install the CR4A 8.5B (100630) upgrade, it told me that I needed to install the full version to the workstation first, since the upgrade does not include the designer.
There wasn't an updated full version displayed online, so I figured the process was to install original Crystal Reports, then perform upgrade.
Is there a new full version available for download?
Ryan Brohman
Kitchener, ON
#23659 - 08/18/10 08:37 AM Re: Crystal Reports Install Error [Re: Ryan Brohman]
Thanks for the idea Michael.
I attempted to run as administrator with same result.
I'm wondering if XP SP3 could be a factor? It's the only thing I can think of that might be different from the last time I did a Crystal install here.
Ryan Brohman
Kitchener, ON
#23660 - 08/18/10 08:40 AM Re: Crystal Reports Install Error [Re: Ryan Brohman]
Hi, Ryan,
I'll email you a link to the full version also.
#23664 - 08/18/10 09:41 AM Re: Crystal Reports Install Error [Re: Softrak Support]
Thank you.
I downloaded that version and attempted to install, but receive the following:
I'm trying to install the designer to the local C: on a new workstation.
Ryan Brohman
Kitchener, ON
#23666 - 08/18/10 09:49 AM Re: Crystal Reports Install Error [Re: Ryan Brohman]
Hi, Ryan,
What environment are you doing the install under? Did you first unzip the downloaded file to an empty folder? I've run into this once before at a site using Terminal Services.
If there is something in your environment preventing the Crystal portion of the install in the normal way, go to the folder you unzipped to and look for, I believe it's, a Phase II folder. Within it will be another setup.exe. Run it and it will install the Crystal portion to the local workstation. When the install begins, make sure you use the Add/Remove button. You'll need the site's Crystal key code also.
#23668 - 08/18/10 10:03 AM Re: Crystal Reports Install Error [Re: Softrak Support]
I am on a Win XP SP3 workstation, no Terminal Services.
I unzipped the file to a network location and then ran StartRP.EXE from that folder. I don't receive any errors, other than the one stating that I don't yet have Crystal installed.
I will attempt to do manual installation from PhaseII folder and let you know.
Ryan Brohman
Kitchener, ON
#23669 - 08/18/10 10:28 AM Re: Crystal Reports Install Error [Re: Ryan Brohman]
That worked.
I ran setup.exe from Phase2 folder. Then I ran the upgrade (RP1P20100630.EXE). Completed successfully.
For clarification on any future installs - Should running StartRP.EXE from the unzipped folder perform both the Crystal designer install, as well as the "for Adagio" component, assuming on a fresh workstation?
Thanks again for the assistance.
Ryan Brohman
Kitchener, ON
0 registered (), 273 Guests and 22 Spiders online.
14626 Topics
