#23648 - 08/18/10 05:14 AM
Crystal Reports Install Error
I'm trying to install CR4A 8.5 to a Windows XP SP3 machine but am getting an error. After entering the install codes and selecting the drives/paths (installed to C:\, report tables on network drive), I'm getting this error:  I have triple checked that the user is a member of the local administrators. I've tried installing from the CD and the zip file. Version is (020328). Thanks,
Ryan Brohman
Kitchener, ON
#23650 - 08/18/10 06:41 AM
Re: Crystal Reports Install Error
[Re: Ryan Brohman]
That's not the current version.
#23656 - 08/18/10 08:14 AM
[Re: Retired_Guy]
Perhaps try "Run as Administrator" on the Install which is different than running as a User who has administrator rights.
#23658 - 08/18/10 08:18 AM
[Re: Retired_Guy]
When I attempted to install the CR4A 8.5B (100630) upgrade, it told me that I needed to install the full version to the workstation first, since the upgrade does not include the designer.
There wasn't an updated full version displayed online, so I figured the process was to install original Crystal Reports, then perform upgrade.
Is there a new full version available for download?
Ryan Brohman
Kitchener, ON
#23659 - 08/18/10 08:37 AM
[Re: Ryan Brohman]
Thanks for the idea Michael.
I attempted to run as administrator with same result.
I'm wondering if XP SP3 could be a factor? It's the only thing I can think of that might be different from the last time I did a Crystal install here.
Ryan Brohman
Kitchener, ON
#23664 - 08/18/10 09:41 AM
[Re: Softrak Support]
Thank you. I downloaded that version and attempted to install, but receive the following: I'm trying to install the designer to the local C: on a new workstation.
Ryan Brohman
Kitchener, ON
#23668 - 08/18/10 10:03 AM
I am on a Win XP SP3 workstation, no Terminal Services.
I unzipped the file to a network location and then ran StartRP.EXE from that folder. I don't receive any errors, other than the one stating that I don't yet have Crystal installed.
I will attempt to do manual installation from PhaseII folder and let you know.
Ryan Brohman
Kitchener, ON
#23669 - 08/18/10 10:28 AM
[Re: Ryan Brohman]
That worked.
I ran setup.exe from Phase2 folder. Then I ran the upgrade (RP1P20100630.EXE). Completed successfully.
For clarification on any future installs - Should running StartRP.EXE from the unzipped folder perform both the Crystal designer install, as well as the "for Adagio" component, assuming on a fresh workstation?
Thanks again for the assistance.
Ryan Brohman
Kitchener, ON
0 registered (),
188
Guests and
Spiders online. |
14578 Topics
