#23599 - 08/16/10 07:10 AM Integrity Check Fix
Sammy Offline
Loc: Summerland, B.C. Canada
In Inventory when we do the integrity check we continue to have 6 erros which read "MIS-FORD,BOM 1, line 1 (thru 6), component PTB-ASE RAIL is invalid". How do I delete the lines in question? I can see that it is Bill of Material however I can not see where this is.
#23600 - 08/16/10 07:17 AM Re: Integrity Check Fix [Re: Sammy]
Ryan Brohman Offline
In Inventory Control, go to Edit > Bills of Material. Then do a find for Item # "MIS-FORD", BOM "1".
Ryan Brohman
Kitchener, ON
#23605 - 08/16/10 08:53 AM Re: Integrity Check Fix [Re: Ryan Brohman]
Sammy Offline
Thanks. I now see the bill of materials however it is grayed out so I will have to change the options somewhere because we obviously do not use that now.
#23607 - 08/16/10 09:52 AM Re: Integrity Check Fix [Re: Sammy]
Sammy:
Is the menu item grayed out? If so then to access this menu item you need to change your security setup.
See if you can access this menu item using the SYS user. If you can then this proves that it is a security setup issue. You can edit the File|Group setup to add this menu item to the appropriate security groups.
0 registered (), 101 Guests and 1 Spider online.
1869 Members
14602 Topics
