#23457 - 08/03/10 06:34 AM Inventory Upgrade = OE Glitch
In IC 8.1C, Item Inquiry/Find when you type the item code and hit enter and it takes you right to the item code in the list.
In OE 8.1C, Item Inquiry/Find when you type the item code and hit enter and it says, "Warning - Record not found". The item code shifts to the right and puts a bunch of spaces in front of it, and therefore Adagio does not recognize the item as a valid code.
#23461 - 08/03/10 10:00 AM Re: Inventory Upgrade = OE Glitch [Re: SusanTennier]
Hi, Susan,
I've been able to duplicate the problem you describe. However, it seems it only occurs when you press Enter in the Item Code field.
A workaround is to press the Down Arrow key instead and select the item from the Finder grid that displays.
Thanks for reporting this to us.
#23462 - 08/03/10 10:28 AM Re: Inventory Upgrade = OE Glitch [Re: Softrak Support]
Hi, yes, we are using the workaround (down arrow) for now. Thanks.
0 registered (), 187 Guests and 4 Spiders online.
14567 Topics
