#23380 - 07/26/10 05:38 PM 64 bit Windows 7 running Inventory
Lynn Offline
New Guy
Has anyone had any luck getting this configuration working? When we start the application, we get the splash screen and then the program closes.
#23381 - 07/26/10 05:57 PM Re: 64 bit Windows 7 running Inventory [Re: Lynn]
Hi Lynn
What version of Inventory?
What versions of other Adagio modules are you running and do any of them work with this setup?
#23382 - 07/26/10 10:17 PM Re: 64 bit Windows 7 running Inventory [Re: Steve Schwartz]
Rick McLeod Offline
Loc: San Jose, CA
We have used W7 64 bit for all of this year with no real problems. This behavior shows up when the Adagio network drive doesn't load after bootup and an error message to that effect shows on the lower right of the monitor for a few seconds and then goes away. Since all of the Adagio software is on the same network drive, no modules will open until the drive is available. The module's splash screen shows briefly and then disappears.
Our normal solution is to open Windows Explorer and observe the network drive for Adagio software. If this is the problem, there will be a large red "X" over the drive letter. Click on the drive letter and see if the "X" disappears and all the drive's directories now show on the right side of the screen. If this happens, any of the modules will now open. You may have to click it several times if the computer has just booted up.
Rick
#23389 - 07/27/10 07:59 AM Re: 64 bit Windows 7 running Inventory [Re: Steve Schwartz]
Lynn Offline
New Guy
Inventory version is 8.1B (091210) The program works on other workstations with no problem.
#23391 - 07/27/10 08:41 AM Re: 64 bit Windows 7 running Inventory [Re: Lynn]
Can that workstation run any other Adagio modules? Have you checked where the shortcut is pointing?
2 registered (Tanya_Belanger, Rebecca Young), 87 Guests and 1 Spider online.
1869 Members
14600 Topics
