#23365 - 07/26/10 04:48 AM Statement /Letter Designer
RobertG Offline
Stranger
Loc: NY,
Hello All,
We are using AR$TEAR.Dat for our statements. We would like to have the page footer show 1-30 days, 31-60days, 61-90 days, 91+ days, like the AR$SSI.dat. when i look at the properties for 1-30 days its calling out "F10, net overdue1 by due date" and the same is on the AR$TEAR.dat for the 1-10Days. Are the Specification codes different for each document? If so, how do I modify? Any help is greatly appreciated
Bob Greene
I.T. and Production Support Manager
Syracuse Glass Company, Inc.
#23367 - 07/26/10 06:24 AM Re: Statement /Letter Designer [Re: RobertG]
Brian Stief Offline
Waterloo Guy
Hi Bob,
The spec codes work the same when code is inserted into any document.
If you are able to print the statement with the SSI spec using your live data, and the totals work fine then, you just need to add or replace the specs from SSI into TEAR. Backup the TEAR spec before modifying.
If the SSI only works properly within SSI, then it is more likely a configuration issue in your live data, and you may need to talk to an Adagio consultant to revise.
Your Adagio dealer/consultant should be able to help you if you are still having problems beyond this. If you need our assistance, please call us at 800-540-3164.
Brian
Brian Stief,CPA,CA
800.540.3164
#23372 - 07/26/10 07:58 AM Re: Statement /Letter Designer [Re: Brian Stief]
RobertG Offline
Stranger
Loc: NY,
thanks Brian, ill let you know how it turns out
Bob Greene
1 registered (1 invisible), 117 Guests and 0 Spiders online.
1869 Members
14600 Topics
