#23316 - 07/20/10 03:13 PM AP Invoice posted in AP wrong year
ltribe Offline
Adagio Graduate
Loc: Kelowna BC
An AP invoice (new employee) was posted using the date of the invoice as the prior year. When the batch was posted and retrieved from the General Ledger, I changed the date to the current year, so the GL is okay, but can you change the date of the invoice in AP module or will it just clear out on the next cheque run? Should I be concerned.
#23319 - 07/20/10 04:01 PM Re: AP Invoice posted in AP wrong year [Re: ltribe]
You shouldn't be concerned.
Now if the date was mistakenly entered into the future instead of the past, you would have a much more complicated situation.
#23320 - 07/20/10 04:06 PM Re: AP Invoice posted in AP wrong year [Re: ltribe]
You cannot change the date of the invoive in AP. It will get picked up by your next cheque run.
The biggest problem with fixing this type of error this way is the fact thet between the wrong date of the invoice (Payables) and the correct date of the invoice (Ledger) your Payables to Ledger to be out of balance by the amount of this invoice.
The correct fix would have been to post a credit note against the invoice using the same wrong date and then re-posting the invoice with the correct date.
1 registered (1 invisible), 64 Guests and 2 Spiders online.
14659 Topics
